2007 LX 50 run problem
LX50
Sun Nov 24, 2019 10:35 am quote
I picked up a 2007 LX 50 that did not run, replaced the battery and got it running but it would not go over 25MPH, Replaced the fuel pick up and spark plug , purchased a new carb. starts and idles fine but when I open the throttle, it dies. I have checked the spark, looks good, checked the fuel supply, good. Where do I go next?
Sun Nov 24, 2019 10:37 am quote
Air filter?
Sun Nov 24, 2019 10:44 am quote
...and is it a 2- or 4-stroke?
LX50
Mon Nov 25, 2019 12:59 pm quote
cuts out when throttle is opened.
My LX 50 is a four stroke ,2007. My problem is something new and I have checked the spark, air intake, fuel supply and think it may be the CID. After reading about other ones with a similar problem, would a bad CID cause my problem?
73 Rally, 74 Rally, 76 ET3, 80 P200, 63 Li125, 65 Li225 Silver Special, 86 Elite 80, 2015 HD Road Glide Special, 2011 Ural Tourist
Mon Nov 25, 2019 3:21 pm quote
Lots of variables on this one-
Did you install the air filter snorkel on the back of the new carb?
If you put the scooter on the center stand and rev the motor does it go full scream or less than ear splitting?
LX50
Tue Nov 26, 2019 7:25 am quote
on the center stand it will come up to to maybe 3000 rpm and then drop off, will go back to idle and do the same again. I have checked the chock and that is moving and pumped the throttle to see if it was gas supply but no change. I think it is electrical, has good spark when I test the plug. Where is the best place to buy a new plug in ICU or what ever they call it for the spark Timing?
Tue Nov 26, 2019 11:08 am quote
Check out scooterpartsco.com for replacement CDi’s
Your Rally Here   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1285s ][ Queries: 23 (0.0338s) ][ Debug on ]
