RAM Mount for 2019 Piaggio MP3 500ie brake fluid reservoir
Mp3 500
Sun Nov 24, 2019 3:55 pm quote
Anyone know which RAM mount will fit over the brake fluid reservoir on the MP3 500 ie? I measured the fluid reservoir cap and it is 1 1/2" X 2 1/8". I don't think the typical brake fluid reservoir Ram mount will fit because this reservoir is recessed a bit, and the length of the typical "universal" is over 4 inches long.
So, which RAM mount will work?
I also measured the mirror arm and it is 1/2" wide.
Anyone have a RAM mount for their phone on their MP3, and if so, which one did you use?
Mp3 500
Sun Nov 24, 2019 6:18 pm quote
I also noticed that the brake fluid reservoir cover is plastic. Do you think it is robust enough for a RAM mount to cover it and not "break" it (no pun intended)?
2015 MP3 500 ie Business
Sun Nov 24, 2019 11:12 pm quote
I use this RAM mount attached to the mirror stem.
Works perfectly without any vibration.
https://www.rammount.com/part/RAM-B-408-37-62U
Mp3 500
Mon Nov 25, 2019 11:01 am quote
Thanks sbaert. That is the one that I also found after doing a little more research of the RAM mounts. That is the one that I will be ordering.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.2084s ][ Queries: 23 (0.0351s) ][ Debug on ]
