300gts: digital clock keeps resetting to 12.00 on start-up
GTS 300 super (US v.)
Wed Nov 27, 2019 5:46 am quote
i have 2014 300 GTS with digital mileage and clock display with 12k km, but as soon as i start the vespa the clock goes back to 12.00 and the total mileage display position. i can set the clock etc with the menu button no problem, but on the next start-up i am back to 12.00 clock.
I checked my battery (3 years old) and it holds 12.6V.
I trickle charged it too but no affect...
I only have usb port accessory installed - nothing extra to increase the load.
Do these vespa's (with digital mileage and clock display) have the renowned clock battery LR43/386 buried in the instrument panel still which could be dying?
What else should i look at? Electrical shorting?
Wed Nov 27, 2019 5:51 am quote
What is the battery voltage while starting? Is it dropping under load?
Any problems starting?
Wed Nov 27, 2019 5:59 am quote
when starting the voltage drops slightly (11.8V) and then goes back to a healthy 14.0V so its charging ok . there is no problem with starting the motor at all. also the resetting does not happen on every start - i would say every five...
GTS 300 Touring
Wed Nov 27, 2019 6:04 am quote
Well, as it's 12:00 and you're in Belgium, have a beer! In fact have a few, you won't care then!
Wed Nov 27, 2019 11:22 am quote
Ok, so it could be that you have a slightly loose battery terminal. It's not unheard of to produce this symptom if you have. But probably more likely is the 'mode' button is faulty/dirty. Another thing to check is that the multiplug on the back on the digital display is pressed fully home and is not moist or corroded. It's easy to get to by taking off or lifting up the plastic headstock to expose the plug. It should be a tight fit but after a while I've notice some customers bikes are showing a loser fitting plug which can again cause this symptom.
1979 P150X, 1983 P200E, 1987 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Wed Nov 27, 2019 1:48 pm quote
The speedoís behavior points to a cut in its 12V supply. Itís either a loose battery terminal (as already mentioned), battery going bad, problem with the harness or the speedo itself (corrosion, cold weld of pins, etc.)...
Sat Nov 30, 2019 3:19 am quote
i re-secured the battery leads and see if it helps. all other tips i think are in the right direction - i also have a feeling it happens more often when it is wet and/or cold.
Wed Dec 11, 2019 6:57 am quote
i can confirm that after tightening the battery terminals the clock resetting has stopped, so yes a logical solution! thanks for your suggestions!
Wed Dec 11, 2019 9:09 am quote
It's very surprising I know, but I've seen this quite a few times. The battery tightening will often cure it. Well done and thanks for posting back about it. It's really helpful to folks. Thank you!
Wed Dec 11, 2019 9:15 am quote
I had the same thing happen on my BV350, it was the keep alive fuse. that feed power to the dash and headlights.
Sun Mar 15, 2020 4:21 am quote
actually the symptoms came back so a decided to go further and open it up and check the harness connections to the speedo itself.
what i found is that my harness was routed wrongly (my vespa was fixed for panel damage before) and it was rubbing against the panel and forks (see picture). when i was trying to reroute the harness it was clearly short circuiting (you could hear by the reset sound inside the speedo)...i also saw that the wrapping material was damaged. i re-wrapped the harness, sprayed the connector cleaner fluid on all the connections, routed it properly (based on the pictures from this forum) and i havent had the clock resetting symptoms since. fingers crossed!
Sun Mar 15, 2020 4:31 am quote
Good! Thanks for the follow up.
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1696s ][ Queries: 27 (0.0282s) ][ Debug on ]
