Cleaned up my reed block, cut out the center post, and blended the opening to the carburetor box. Looking at the reed block itself, wondering if I should open up the block around the mounting point for the reed. I would have to angle it as the opening is sized for the carb box already and I couldn't take that much off.
Should I open up the block on the reed side? You can see the line in the block for the oil line.
This looks like there is to much blocked to me.
