winter project? - adding a Tachometer
Tue Dec 17, 2019 6:31 am quote
Trail Tech 72-A00
$28.78 - Amazon
I installed this on my 2012 Kymco in 2013.
I used 2 sided Red 3M tape. (No drilling in the scooter)
Fished the wires without removing any panels - except for the battery cover.
I check it every now and then after a ride - to see what my max RPM's were. or, while riding to see what I'm turning while on a country road cruise. It also records engine hours.
After 6 years it is still working fine.
Removed the seat bucket & wrapped as close to the spark plug cap as possible, then enclosed it loosely.
Aprilia Scarabeo 500
Fri Dec 20, 2019 9:46 am quote
It appears that model you have has been discontinued. I found model# 742-A00 on Amazon for $39/shipped. Maybe looking to try it out on my Scarabeo 500. Looks like a nice compact unit.
GTS 300 Super ABS/ASR, BV 350 ABS/ASR
Sat Dec 28, 2019 9:16 am quote
Nice! The Piaggio PMP app has a tachometer...
Derbi Boulevard 125 4t
Wed Feb 05, 2020 11:08 pm quote
Hi,
Was using something similar, but decided to go next level and created this
It has ressetable trip function, shows rpm, exact speed and has two colour schemes: one like in picture and another high contrast black on white for sunny days. It hooks up to pickup coil via optocoupler for rpm and i have added hall sensor into original speedo for speed. Based on esp8266 chip and 2.2 inch TFT display.
Next step is to add this screen in place of original needle speedometer. Also display has enough room left for fuel level indicator, but not sure if i need it.
S150, Beo 500ie
Wed Feb 12, 2020 8:30 am quote
So...are you going to tell us how we can get a kit like that from you, or source it on our own, or are you just going to leave us in suspense like this?
Wed Feb 12, 2020 10:53 pm quote
Don't have much time at the moment, but will try to put schematics, code, partlist etc. together soon
Thu Feb 13, 2020 12:31 am quote
OK, lets start.
PARTLIST
Main processing unit is ESP8266 in form of "D1 mini" with ProtoBoard shield. Both can be found at ebay for cheap
Screen is also from ebay, 2.2 inch tft ili9341 320x240, there are several variations of them, mine has 3.3v logic level (no logic level shifter chip). As i use 3.3v to power it, J1 should be shorted by solder.
Step down converter 12V to 5V.
4N35 optocoupler to get RPM from pickup coil.
A3144 hall sensor to get speed. Placed inside original speedometer near spinning magnetic disk.
1M, 10k, 4.7k resistors
2x 1N4007 diodes. I think one would do the job, but i'm too lazy to remove it and do tests.
25V 10000uF electrolytic capacitor or several in parallel, i have used 6 capacitors 2200uF each. This will provide enough power for D1 mini to save odometer and trip to memory after switching ignition off.
Pushbutton. Short press switches between color schemes, long press (over 3s)- resets trip.
It is possible to use capacitive sensor placed behind plastic trim, so no hole drilling etc.
Thu Feb 13, 2020 12:52 am quote
Hand drawn schematic
Pins GND, 5V, 3.3V, RST, A0, D1-D7 are on D1 mini board
Screen connection:
Screen -> D1 mini
Vcc to 3.3V
GND to GND
CS to GND
Reset to RST
RS to D3
SCK to D5
SDI to D7
LED to Vcc
SDO not connected
Different screens have different names for pins.
Thu Feb 13, 2020 1:08 am quote
Coding part
I need to add lots of comments and do translation of code i have created (some parts are borrowed ). Once done, i will upload it for your access.
I will not teach you how to configure Arduino IDE to work with D1 mini, there are plenty tutorials online.
https://averagemaker.com/2018/03/wemos-d1-mini-setup.html
https://gist.github.com/carljdp/e6a3f5a11edea63c2c14312b534f4e53
Code depends on library TFT_ESPi which has specific configurations for each screen/setup
https://github.com/Bodmer/TFT_eSPI
Later i will also attach zipped library from my PC with correct config and fonts to work this specific display.
Thu Feb 13, 2020 2:21 am quote
https://github.com/rverzinkevicius/tacho_speedo
main code is in tacho_speedo.ino
You will nedd to extract TFT_eSPI-master-20200213T100157Z-001.zip to Documents\Arduino\libraries on your PC
There are few things to mention. First you will need to change wheel circumference to reflect your wheel size in centimeters in line 41
int wheel=156;
Next you will need to uncomment (remove //) two lines 83 and 84 in code
// dispodo=0.1;
// allodo=5660.2;
Change allodo to mileage you have on your scooter, upload code to D1 mini, then comment/delete those two lines and again upload code.
To change km to miles, i think it should be enough to multiply your wheel size by 0.621371, for example line 41
int wheel=156;
should be
int wheel=97;
and change line 328
tft.drawString("km/h",236,290);
to
tft.drawString("m/h",236,290);
Thu Feb 13, 2020 2:38 am quote
Should be it
Thu Feb 13, 2020 6:11 am quote
cool project. thanks for posting that info.
Sun Mar 01, 2020 10:15 pm quote
How it looks like while riding
https://youtu.be/MsDIQn17gwU
Wed Mar 04, 2020 11:46 am quote
That looks awesome! Thanks for sharing.
Rallies Europe 2016   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1485s ][ Queries: 25 (0.0307s) ][ Debug on ]
