Wanted: Low mileage Original Piaggio (no aftermarket) PX200 EFL transmission. The type with the shims on both sides of the output shaft. Must be in good to excellent condition. I am looking to buy the whole setup or will also buy each separately. In case you're not sure, this is not the same transmission as found in the US market P200e.
Parts wanted:
Christmas tree (input gear cluster with primary gear)
Output shaft
Gears
Selector box
Gear selector plunger
Rear Hub
Washers/spacers/shims
Please send message.
Thanks!
