Used MP3 500 - what to look for
GTV300, P2, VB1T, Lambretta TV200 & sidecar
Wed Jan 08, 2020 5:42 am quote
Hi all
Going to look at a 2016 500, with 8000 miles on the clock - one owner with service history.
Anything in particular you would reccomend I look at / for?
Thanks in advance for any help you are able to provide - these bikes are obviously not cheap.
Wed Jan 08, 2020 6:32 am quote
When riding, feel for a notch on the steering, should be dead center and could cost 600 to fix.
2015 MP3 500 ie Business
Wed Jan 08, 2020 8:01 am quote
Make sure the owner can provide legit proof that the first service (@600mi-1K km) was performed by a Piaggio MP3 dealer.
That is the single most important service that bike will need i.e. retorquing the head bearings and greasing them liberally.
Ditto for proof of the 6K mi/10K km) big service (head bearings checked and regreased, belt, rollers, sliding shoes, filters, fluids, etc.)
IF this was skipped/postponed/delayed, then skip purchase of said MP3
Wed Jan 08, 2020 10:54 am quote
600 mile service is change the oil engine and hub. Then a check list of stuff to look over. No re torquing of the head or head bearings, what ever they are
Wed Jan 08, 2020 12:07 pm quote
Well smart guy, then you must know something that nobody else does. Without lubing the steering bearings on a very regular basis (and there are at least 6) on the MP3, you are guaranteed to get the dreaded steering notch problem that is the Achilles heel of every MP3 ever made.
Wed Jan 08, 2020 3:44 pm quote
6?
Shoot.... Please do show me where the other two are that require lube...
Wed Jan 08, 2020 7:12 pm quote
Madison Sully wrote:
6?
Steering column shaft (upper & lower bearings)
Gilera Fuoco 500ie
Wed Jan 08, 2020 11:50 pm quote
and tell everybody how you wanna lube those
you need to take everything apart to get access
Those aren't load bearing bearings will last 60 or more thousend km's even without grease
last weekend a customer came in with a 250 from 09 always standing out side and nearly 80.000km just put some WB40 in it and it turned smootly again
Thu Jan 09, 2020 4:48 am quote
Oh you mean Steering Head Bearing? No that doesn't need service. But you are right the fork bearings do need greasing.
2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Thu Jan 09, 2020 6:37 am quote
Re: Used MP3 500 - what to look for
Gage wrote:
Hi all
Check the Air Filter Box, see if it has signs of "Oil Blow" also the bubbles.
Keith,
Marietta, GA
Thu Jan 09, 2020 9:25 am quote
That is the penny wise, pound foolish solution.
WD-40 is a useless and hopelessly outdated product, except for removing old stickers. It is not a grease or a lubricant. At best it is a water displacer.
Sure removing the steering column is a bit of work, but if Piaggio had spent the extra 2 seconds and 2 cents to lube everything properly using a top quality grease we wouldn't be having this conversation.
No bearing has ever failed from having too much grease.
BV250
Thu Jan 09, 2020 9:56 am quote
If any vehicle required me to take apart the steering system to relube the bearings every 10K kilometers, I wouldn't ever want to own it. That's just ridiculous in 2020. The maintenance schedule you propose is more appropriate for a 1920 vehicle.
Thu Jan 09, 2020 10:25 am quote
Lubing the steering column is a one time deal. It is the 4 fork bearings that require to be lubed at least every 10K km. I do mine every 5K km.
Again, IF Piaggio had spent the time and used a good quality permanent lube this wouldn't even be a point of discussion.
The first time I lubed my fork bearings (even after the 1K Piaggio service) at 5K km, it took a entire cartridge of grease to fill up the forks entirely until grease appeared from all 4 bearings.
Thu Jan 09, 2020 11:01 am quote
Same here on your comments, but I top mine off every winter.
It amounts to a few pumps...
Once I see it leaking out, I stop pumping.
During the summer months, I will get some leakage, but its not that bad.
Keith,
Marietta, gA
Thu Jan 09, 2020 11:45 am quote
This is actually false. The amount of grease installed in high RPM applications is metered accurately; it IS possible to put too much.
Maybe not steering columns, and yes, I'm being pedantic.
Fri Jan 10, 2020 5:59 am quote
That is because Piaggio greases the bearing before it's installed. Only reason you have to use so much grease when filling with a grease gun is you are filling the whole empty area of the steering tube.
Fri Jan 10, 2020 8:25 am quote
I am very well aware Piaggio greases the bearing before installation, and therein lies the problem. They use too little and use a subpar grease that deteriorates and hardens over time. Very similar to how the factory installed coolant loses all of its properties within 24 months resulting in muddy coolant systems if not flushed in time.
My steering column had practically zero grease on the lower bearing, and absolutely no grease at all at the upper bearing.
Filling the empty fork space with grease ensures that the bearings will never go dry or allow contaminants to enter the bearing. Essentially the extra volume grease lubricates the bearings continually.
As I said, oil and grease are cheap. Engines and transmissions are not.
Fri Jan 10, 2020 8:49 am quote
Thank you all very much. Just pulled the trigger, needs a belt and has 'the notch' which I showed the car dealer who had taken it in part exchange, meaning I got a lot of bike for what I paid.
Now to fix the notch and the belt!
Thanks again and ride safe
Fri Jan 10, 2020 9:29 am quote
How many miles on that current generation MP3? The notch on such a newer bike is a dead giveaway that it very likely never got the critical service at 1K km (600 miles)
You will need at least the tool to losen the fork ring nuts, 2 new fork bearing kit sets, one for the left side and one for the right side. They may or may not be different part #s for the other side.
Be aware, if you do not know how to bleed the tilt lock and ABS systems this is a job that should be left to a qualified MP3 repair shop.
Here is a pic of one kit (does one fork)
Fri Jan 10, 2020 9:50 am quote
Plug the brake lines on the forks when you pull them so you don't loose all the fluid. I didn't and it was a bitch getting all the air out of the calipers.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1945s ][ Queries: 27 (0.0402s) ][ Debug on ]
