Learning how to order parts
1986 T5, 1971 Sprint
Mon Jan 13, 2020 3:30 pm quote
As I take things apart on my scooters, I usually make a note of parts Iím going to need. A few weeks ago I ordered bearings, seals, and gaskets along with a bunch of other stuff for my 71 Sprint which also has a 74 Veloce motor.
Today I rebuilt the Cush drive and I checked to see if the bearing was included in the set. I looked up my previous order and thatís when I noticed the bearings were listed for Sprint V(1) and V(2). Damn!
I checked my engine serial number and I have a V(1). Luckily I ordered the correct bearings. But I also ordered the incorrect seals and engine gasket set.
I double checked the engine gasket fit and itís slightly off. 2 of the engine seals are the same but flywheel side seal is a different size.
So live and learn, write down your engine serial number and order the right parts the first time!
Mon Jan 13, 2020 6:25 pm quote
I get 90% of my parts from Scooter Mercato. The website is easy to use and if you have a question, you can call and talk to a real person (usually David) as long as it is Monday thru Friday. On weekends I just use email and get a response back by Monday afternoon.
1963 Allstate, 2005 Vespa PX150, 2001 Harley 95 ci Dyna
Mon Jan 13, 2020 7:39 pm quote
I agree with Tierney. Scooter Mercato is a great place to order parts. David is very helpful and if he doesnít have the part, he will try to get it for you.
Mon Jan 13, 2020 7:54 pm quote
And you can order parts from SIP thru scooter mercato and save on shipping .
Mon Jan 13, 2020 8:08 pm quote
+1 for David and Staff at Scooter Mercado.
73 Rally, 74 Rally, 76 ET3, 80 P200, 06 PX150, 65 Li225 Silver Special, 86,95,96 Elite 80s, 2015 HD Road Glide Special, 2011 Ural Tourist
Tue Jan 14, 2020 1:08 am quote
I've ordered parts books for every scooter I have (ebay/scooterwest). When it comes time to order, I can add the Piaggio part numbers to every item. It also helps if I need to show someone how the scooter internals work.
It cuts down on errors and helps the guys filling out my order. The scooterwest computer system needs a part number, then quantity. I save them time by adding #123456 instead of saying something generic like a gasket. That makes them have to get the book, look it up, type it in, waste time, waste time and it might not be correct (ie. carb gasket instead of air box gasket.)
I've also took the extra steps to order through domestic shops. (Scooterwest/ Mercato/ Scooter Speed.) SIPs system is pretty good, but sometimes their pictures dont match the item listed. Im paying a little extra for their services, but it definitely has helped cut down on order errors having someone local to speak with and make sure I get the correct item.
bare metal cafe racer
Tue Jan 14, 2020 6:40 am quote
Turns out the local scooter pros are SIP dealers. I donít think itís that uncommon worldwide - just have to order enough per month. Worth always checking if you can get SIP stuff locally.
Hope itís ok to give them props. But tops blokes who are very knowledgeable and experienced. Ordering from them means being backed up by that experience. And steered in the right direction plenty of times too.
And a cool website...
https://retroscooter.nz/
bv350, Brutale 910
Tue Jan 14, 2020 8:35 am quote
af1 racing has all the parts catalogs online, no?
also, how does 1 order SIP parts through Mercado? Call in w/ SIP part # ? Or? TIA.
Tue Jan 14, 2020 9:04 am quote
http://www.scootermercato.com/Scooter-Parts/Vintage-Vespa-Parts/SIP-Part
'63 VBB2T - '76 Sprint V - '18 300 GTS Super Notte
Tue Jan 14, 2020 9:13 am quote
Re: Learning how to order parts
Anybody has an idea what's the difference between V1 and V2?
Years? Model differences?
When I search, I only find first series Sprint and later Sprint Veloce.
1979 P150X, 1983 P200E, 1987 T5, 1996 PX200E, 2011 Yamaha Fazer 600 S2
Tue Jan 14, 2020 12:32 pm quote
VP, let me guess. The problem with the gasket set was at one of the studs. As I learnt, early Sprint V. cases were basically 2 port Sprint cases converted to 3 ports. Then they changed the layout of the studs and made them the same as on all of the later models (Rally, P, PX). I had the same problem on my friend's Sprint V. I rebuilt a while back...
Old stud placement
New stud placement
Sprint v1 gasket set
Tue Jan 14, 2020 12:47 pm quote
I had the same issue on my sprint v engine..
74 Super, 75 Super, PX project, LML off-roader and new to 2018, '66 Blue Badge Smallframe
Tue Jan 14, 2020 5:52 pm quote
That's what SIP describes as Grade A - for a perfect repair!
I did the QLD Mille with Christiaan. Really nice guy and just as sick as the rest of us here!
Tue Jan 14, 2020 6:44 pm quote
You are correct, and in a pinch the Sprint V2 gasket would probably work. I will say that the SIP ordering experience is far and away head and shoulders above anything we have here in the states. Itís the shipping coupled with the minimum order rules that are a pain. Their prices, product descriptions, ease of ordering are just better.
Rallies Europe 2016   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.1641s ][ Queries: 28 (0.0368s) ][ Debug on ]
