Dtskedwards wrote:
Thank you for the info.
If possible I would like to restore the sensor.
I wonder if I could reset the system to get it back.
no reset. just check it with a multimeter to ensure the contacts open and close. if the sensor is bad the only way to get a new one from piaggio is buying a complete seat. highly recommend finding a used one thru ebay. you can use any of the mp3 model seats for the sensor as that is the same in all, just have to remove it an install it into your seat if you get a different model seat.
