ET4 125 Leader engine refurbishing.
KTM LC4 Adventure, Husaberg FE501
Tue Jan 21, 2020 11:13 pm quote
Hi folks! This is my first post here and first of all i want to thanks for such a nice forum and a lot of great projects here!
I'm coming from a motorcycle world (mainly KTM) and this is my first time to work on scooter or Vespa ever. Friend of mine asked to do some job on his Vespa and in this case i'm learning by doing. Moped needed some love, weak/not working electric starter motor, kickstart mechanism damaged. He want's to change piston and IF the cylinder will be in bad condition than go for bigbore version.
[img][/img]
Tue Jan 21, 2020 11:16 pm quote
Please confirm that this is Leader engine
Tue Jan 21, 2020 11:21 pm quote
One of starter motor bolts is broken, will try to weld some nut and remove it.
Cleaned, greased and assembled kickstart lever and spring, somehow managed to do it without special tool and now it works perfect!
Wed Jan 22, 2020 4:19 am quote
Before head removing checked valves, intake was bit tight, about 0.09 mm and exhaust bit loose (0.20mm)[/img]
Wed Jan 22, 2020 4:25 am quote
Looks like piston rings was worn out, but cylinder looks in good shape.
Wed Jan 22, 2020 4:29 am quote
Sorry, i'm still learning this forum and adding pics is harder to work on engine itself!
Wed Jan 22, 2020 10:12 am quote
Cyliinder surface looks OK.
Thu Jan 30, 2020 9:44 am quote
Piston cylinder wall clearance
Hi guys!
Today measured a cylinder bore in shop with right tools and now it's time to order a piston. i haven't any experience with such a small bore engine and i the clearance about the same as larger bore engines (0.060-0.070mm)?
The cylinder bore is 57.050mm to rear-front and 57.020mm side - side.
i guess piston should be about 56.980?
Thu Jan 30, 2020 10:05 am quote
Measures
Vespa Gt 200 '03
Mon Feb 03, 2020 4:19 am quote
Hy!
Yes, it is a leader engine
S 190. Custom VNB 150
Wed Feb 05, 2020 9:14 pm quote
Good looking pics.
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1697s ][ Queries: 27 (0.0448s) ][ Debug on ]
