Stem sliding locking device leak
2016 MP3 500cc Sport ABS
Mon Feb 03, 2020 7:42 am quote
I'm looking for advices,
I was checking the scooter yesterday when I noticed excessive oil around the left "sliding locking device".
Each time I activate the roll lock, I see oil coming out of it. It has never happened before and the right side one does not leak at all.
My question: Is there something I can do to prevent this part from leaking or I need to replace it...period?
Here is the culprit after I cleaned it.
2009 MP3 400, 2004 Honda ST1300
Mon Feb 03, 2020 9:53 am quote
The parts diagram only shows the complete assembly.
I would bet that it's just an o-ring that is leaking. If it were me I'd try to disassemble it and see if I could replace the rubber. If not, then you replace it.
part#601727 Not inexpensive.
If it's leaking, it won't be long before the tilt-lock starts beeping at you because of low fluid.
2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Mon Feb 03, 2020 11:18 am quote
I would check ebay, I thought I saw a set posted a few days ago.
Keith,
Marietta, GA
Mon Feb 03, 2020 1:08 pm quote
Yes, I'm not using the roll lock right now to avoid having this lovely horn signal going off.
Any idea if it's easy to disassemble ? I saw some for sale on e-bay for about $80 otherwise.
Mon Feb 03, 2020 1:22 pm quote
Don't buy used, you don't know how old they are and could do the same thing shortly.
Mon Feb 03, 2020 1:27 pm quote
$68 at www.motorcyclespareparts.eu plus $35 shipping. Buy some other stuff to make it worth the shipping. It's $35 flat rate. So load up on spares.
I bought crash bars, windscreen and other stuff and shipping was only $35.
https://www.motorcyclespareparts.eu/en/piaggio-parts/601727
2015 MP3 500 ie Business
Mon Feb 03, 2020 1:49 pm quote
Re: Stem sliding locking device leak
The only permanent fix is to replace the unit, BUT you can minimize the wear on the tilt lock system by minimizing its use.
In other words, use the centerstand as much as possible and unlock the tilt lock before turning off the bike.
This will help prolong the life of the tilt lock system since there will no pressure.
Mon Feb 03, 2020 3:24 pm quote
Haven't had a reason to take mine apart yet. Bleeding the system is enough of a chore that I'm not going to do it just for fun either.
Gilera Fuoco 500ie
Wed Feb 05, 2020 1:03 am quote
no need to buy new ones just take the rubbercap off push it in a few times and wipe it dry
its a pressure valve there only some dirt between it
Wed Feb 05, 2020 9:12 am quote
Oh really? I'll try that and hopefully it will work.
Thu Feb 06, 2020 6:49 am quote
That's a new one for me...
Never had the problem, but will make a note on this one.
Maksor to the Rescue ;o)
Keith,
Marietta, GA
Tue Feb 25, 2020 11:23 am quote
It works... I pushed it few times and cleaned, wiped it... No more leak when I activate the Roll Lock.
Thank You Maksor
Tue Feb 25, 2020 12:40 pm quote
Maksor has so much knowledge of the MP3 in his head.
2009 MP3 400ie
Fri Mar 27, 2020 11:52 pm quote
same problem as mine
I did what Maskor suggested so i tried to push it in but its not working Ive tried to push it gently until i can feel that its pushing in and WALA after several tries its PUSHING IN AND OUT... i guess it got stuck up on dirt just like what Mr maskor said. Thank you for the tip...
But my next question is in case I need to replace an O-Ring how will I bleed the system?
Kymco AK550
Sat Mar 28, 2020 12:54 am quote
One of mine was slightly leaky so I rolled back the outer boot and sprayed it with some GT86 ( which is similar to WD40) then cleaned it off externally. This did the trick. I wouldn't do this with brake components for fear of contaminating the brake fluid but for a system that is not safety critical its worth a try.
2008 fuoco
Sat Mar 28, 2020 1:00 am quote
Re: same problem as mine
See my topic on page 1 "Tilt lock brake units strip down."
Mon Mar 30, 2020 2:39 am quote
Easiest way is to get a big syringe and some hose and push the fluid up from the locking cylinder to the master cylinder.
Rallies Europe 2016   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1564s ][ Queries: 27 (0.0397s) ][ Debug on ]
