LX150 2009 Rear Break Replace?
LX150
Wed Feb 05, 2020 11:20 am quote
My rear break has pretty much stopped working. Not in a broken cable kinda way but when I squeeze it the bike wont stop (moving forward or back). Is this something where I just need to adjust the break cable or replace the drum breaks. How can one tell? The scooter has about 5k miles on it.
Wed Feb 05, 2020 12:16 pm quote
With 5 thousand miles your brakes shouldn't be worn out but if San Fran is as hilly as I think it is- then maybe. My scoots have their original pads and/or shoes and they have 25-35 thousand miles on them. Brakes are nothing to play with so I would have a pro check them out.
Bob
LX190, Primavera
Wed Feb 05, 2020 12:27 pm quote
It probably needs adjustment...
LX150
Mon Feb 10, 2020 1:43 pm quote
I did the adjustment and it helped a bit but the break lever handle is really hard to pull now (it has about 10mm until it connects with the break) and the tire still spins some and the vespa doesn't come to a complete stop.
2009 LX 150, 2008 GTS 250
Mon Feb 10, 2020 2:56 pm quote
You may have leaking gear oil on your brakes. My LX had the lip seal installed backwards by Piaggio. A little gear oil would make the brakes not function at all. Start by looking for oil on your rear wheel. Or have your dealer check it out.
Bill
Vespa LX 125
Mon Feb 10, 2020 4:21 pm quote
Cable might have seized up from rust or a frayed cable wire.
Had this on my lx.
Take the cable off at the brake shoe end and see if it pulls easily both ways.
Lx 50 4T, GTS 250, Something Chinese
Tue Feb 11, 2020 7:02 pm quote
How far are you from changing your rear tire? You would be able to explore more with the wheel off.
Fri Feb 14, 2020 10:39 am quote
Thanks for the info. This is exactly what I needed to hear my lx 50 drum brakes are kind of mushy.
I will try to adjust them them tomorrow and take it for a test ride.
Land of 10,000 Scoots Rally   Vespa Wasp Pin Badges   Cool Ass scooter seat cover
[ Time: 0.1534s ][ Queries: 27 (0.0383s) ][ Debug on ]
