2005 PX150
2005 Vespa Piaggio PX150
Tue Feb 11, 2020 11:44 am quote
While shifting gears it, going from 1st , 2nd, 3rd or 4th it feels and sounds rough while engaging into that gear. It is not smooth at all. It goes into gear OK but I'm concerned that eventually this might cause a tranni problem. There are only 2300 miles on the scooter. Before I start poking around, thought I'd look to the forum for some guidance. I recently changed the gear box oil but I know that isn't the problem. The shifting has been the same since I purchased the scooter a few months back.
PX 150
Tue Feb 11, 2020 12:05 pm quote
A first step would be for you to adjust the shift cables and to check your clutch cable adjustment to be sure that the clutch is being disengaged fully.
Tue Feb 11, 2020 12:43 pm quote
I don't know your history with Vespas. Is this the first time that you have ever operated a scooter that has a clutch?
Land of 10,000 Scoots Rally   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1288s ][ Queries: 25 (0.0343s) ][ Debug on ]
