250 GTS Engine Seals/Orings?
2009 Vespa GTS 250
Wed Feb 12, 2020 5:05 pm quote
I am doing a top end repair on my 2009 GTS. I have found the base, cylinder head and valve cover gaskets, but can not find the 4 cylinder stud orings or the flat valve cover seals. Does anybody have the parts numbers I could search for or know where I could order them?
Last time I was on here I was pushing the scooter home when it died on me and would not restart. Was blowing the airbox full of oil and had fouled the sparkplug. I disassembled the top end today and found the 2nd and oil control rings lined up and the top ring at about 2 oclock from them. Everything else was perfect. Bet that if I stagger the rings it will run better!
Sponsor
Granturismo 218
2009 Vespa GTS 250
Wed Feb 12, 2020 6:27 pm quote
Thanks Motovista. I figured that you had them but I could not find them on your web site. By my calculations it is less expensive for me to order the individual pieces than the gasket kit as the kit contains a large gasket and oring that I dont need. I will order the parts tonight. Thanks
Thu Feb 13, 2020 6:27 am quote
AF1 racing has a excellent parts supply, and the also have the parts breakdown for your scoot to look up exactly what you need.
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1336s ][ Queries: 23 (0.0251s) ][ Debug on ]
