Fix my 250 or replace with new 500?
MP3
Sun May 17, 2020 2:53 pm quote
I'm facing a hard decision and would greatly appreciate feedback from experienced MP3 riders.
I have a 2007 250 that needs new bearings. It has almost 13,000 miles on it. Most of those miles are mine. The mechanic at the Vespa shop said he didn't think it was worth putting the money into it. If I don't fix it, I have a couple of options: 1) Buy another used 250 or 2) Buy a new or like new 500.
My concerns about buying a used 250 is that I could run into the bearings problem again in the near future. I also can't buy one that was made in 2018 or 2019. The pros of buying a used 250 is that it would be familiar to me. I'm used to a 250. I know I can handle it.
My concerns about buying a 500, once I get over the price, is I'm concerned it will be too big and too much for me to handle. Does anyone know if the 500 weighs much more than the 250? I'm female, 5' 3" and weigh 165 lbs. The 250 is the largest and fastest scooter I've ever owned.
Any thoughts or ideas?
Sun May 17, 2020 3:00 pm quote
If you mean the steering bearings have the notch in them, the cost of replacing both sides can be high indeed, but not so high as replacing the scooter.
If you do go to buy a used 250, it will be of similar vintage to the one you have, so prone to notch. Similar story with older 500s. I forget which year Piaggio fixed the issue in their factory; they were being set too tight and not much grease at the factory.
What is the price you are quoted to replace the bearings (if indeed it is the steering bearings we're discussing)?
Sun May 17, 2020 3:03 pm quote
If I recall correctly the MP3 500 is about 100 lbs heavier than the MP3 250.
If you are comfortable with the 250, it will take a few miles to get comfortable with the 500, in my opinion. It's different, a bit heavier, and faster.
The MP3 400 of similar vintage is less of a weight difference, but has good highway capability.
MP3
Sun May 17, 2020 4:18 pm quote
I do mean the steering bearings. I was told approximately $2000.
Sun May 17, 2020 6:28 pm quote
If I recall correctly the parts are about $100. It was a few years ago but I heard total cost on replacement of all the steering bearings would be more like $1100.
Ouch.
I mean, there's a lot to take apart to do the job, but damn.
Cost of captive audience I guess.
Not a whole lot of MP3 mechanics around....
Sun May 17, 2020 8:50 pm quote
Ouch.
Agreed.
If you have a friend who is willing to have a go (I gather you are reticent to do so yourself), just do the 'Gonzo Tweak':
Short term fix for "notch"? - It works...
It would probably work for you for the next 13,000 miles, or 13 years.
2016 Mp3 500ie Sport
Sun May 17, 2020 9:29 pm quote
500cc
Hi
I think you can probably handle the 500cc.
I'm 5ft 5in with an average build and weigh around 130 lbs with a slim build and am not very muscular compared to the guys at the office.
The 2014 250cc is about 493 lbs
The 2016 500cc is about 570 lbs
The Mp3 500 was my first motorcycle and the initial joy of owning a bike soon turned to fear. The first rides around town, first-time parking it, first time on a slopped stop sign; it was too heavy. I accidentally parked it on a down slope and had to muscle it back out. Then I wasn't strong enough to engage the center stand.
I almost re-sold the bike due to the size.
But I stayed with it, watched videos, learned techniques, practiced. I'm now about 2 years and 5,000 miles later. I barely notice the weight anymore. I use the tilt-lock when parking which makes the size and weight a non-issue so long as I plan ahead before parking it. I've dropped (gently) 5 times at stop-signs and each time I've managed to heft it upright again and continue.
Being a 500cc it does have more power but that is tempered a bit by the greater weight. Just keep it in "eco" mode for the first few hundred miles to get used to it and roll-on throttle slowly. Its fast but not speed-bike fast. Even the 500cc wont be winning any races or setting track records.
The 500 is a bigger bike, no getting around that.
You have an advantage I didn't, you've already handled an Mp3 250 so you're already familiar with all the intricacies of the type.
Go for the 500.
It will serve you well and the higher performance will open up new worlds of travel and safer highway performance.
2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Mon May 18, 2020 11:37 am quote
Re: Fix my 250 or replace with new 500?
I would fix it...
The 250 is the best of both worlds...
You have a MP3 Scooter, with all the older Tech from the Vespa bikes.
Engine is easy to fix, and you could always bump it up to a 300.
I would get rid of my 500 before selling my 250...
Keith,
Marietta, GA
Mon May 18, 2020 11:42 am quote
Get the 500, get rid of the damn 12" rear tire. 500 loves the highway speeds. Just got my MP3 500 back on the road this spring and remembered how much I like it.
Mon May 18, 2020 11:50 am quote
I am in the camp of fixing it. not for what the dealer wants to charge though.
replacing the front bearings should be more reasonable for $700-800.
2009 MP3 400
Mon May 18, 2020 1:45 pm quote
Fix it! The cost of the parts is negligible. The labor can be negotiated. I'd be looking for a different mechanic. There's gotta be someone else in the Philly area that can do the job for a whole lot less.
Mon May 18, 2020 2:02 pm quote
Well problem there is you want someone that has done it before and you need the special tool to properly tighten the spanner nuts.
Also back to some one that knows the scooter. Getting air out of the brakes can be a bitch, still can't air out of my calipers from the job on the MP3 500.
Have had the butt of the scooter almost straight up in the air trying to manipulate the air out.
MP3
Mon May 18, 2020 2:25 pm quote
Is replacing the steering bearings the kind of repair that requires a certified Piaggio/Vespa mechanic? Or could a good motorcycle mechanic do the job without running into problems?
MP3
Mon May 18, 2020 2:28 pm quote
I didn't read Web-Tech's response closely enough before asking my follow-up question. It sounds like a special tool is needed and that someone who has done it before is the way to go.
Mon May 18, 2020 2:51 pm quote
the tool can be bought. I have a set. Heck I would even let you borrow them with a deposit of course. just pay the $10 shipping both ways as well.
if interested send me a private message.
the special tool is the same tool used on the vespa steering head bearings as well so its fairly common.
BV250, BV500
Mon May 18, 2020 3:04 pm quote
I have a 250 2008 BV, not an MP3. I had an MP3 500, also 2008, for a while. It was way too clumsy for me, weighed too much. I couldn't push it around in the garage without working hard, and it tipped over twice, in the garage. I work on scooters a lot, and I love them, but I did not love the MP3 500. I sold it, much happier.
I also recently have been working on a 2006 BV500, same engine as the MP3 500 but just 2 wheels. It's not as clumsy and feels less awkward on the street but it is heavy. Just today I took the BV250 out for a ride, then took the BV500 out for the same ride. I'm still partial to the BV250.
I'm 5' 8" tall, 165 lbs., and fit and strong. If it were my choice I'd do some shopping around for alternate prices on the bearing repairs. If you are going to do some long haul riding, with luggage, the 500 might make sense, but if the 250 suits you, fix it.
Mon May 18, 2020 4:25 pm quote
I have the special tools (there are two of them) too.
But really, at the end of the day a hammer and punch would probably be more or less fine.
Adjusting the steering bearings is about the last thing to worry about though.
Bleeding the tiltlock and brakes, well there's where the fun lies.
And that's after you actually replaced both sets of bearings and greased the everloving lots of grease into them.
Put it this way. If my ride needed new steering bearings, I'd put aside a weekend and do it. If your ride needed new steering bearings, I'd suggest you spend the $1100 to get it done. $2000? No, that's too much, look elsewhere. Not a general motorcycle mechanic, it's totally different from other motorcycles. And if that $2000 estimate is the only one around, well, that sucks.
Mon May 18, 2020 4:28 pm quote
But yeah, Gonzo tweak all the way for the short term fix. May well last you a few years.
Mon May 18, 2020 10:35 pm quote
Yeah totally agree about the gonzo tweek. it's very easy to do and of course costs nothing but a tub of greese to pack out the bearings afterward's.
The best version of the mp3 is here in the UK. It's a 300cc engine but looks just like the 250. ( not the yourban ).
Iv had almost a dozen mp3s over the years and as long as the tilt lock is working it didn't matter what version I had,they all could very easily be moved around and pushed from behind down narrow parking bays.
Speed wise I liked the 400 better than the 500 as it gave better mpg and less troublesome engine.
I'd fix ya 250 and then just keep a look out for maybe something different, by the way the piaggio x10 350 is a beast of a scooter and is still the best motorbike slash scooter Iv ever owned.
Tue May 19, 2020 2:03 am quote
You're asking the question in the MP3 forum, so people assumed it was an MP3.
Why not try again in the Gen section?
MP3
Tue May 19, 2020 7:31 am quote
Thanks to everyone for your help. When I posted, I wasn't sure anyone would respond. So it's much appreciated.
I have always loved my MP3 250. It's the right size and speed for me. (I don't do highway riding. Most of my riding consists of back roads to and from work or scenic rides.) There is an independent mechanic down the road from me who has a good reputation. I will talk to him about doing the Gonzo work around. If he's not willing, I will call Piaggio mechanics up and down the East Coast and try to find someone who is willing to replace the bearings at a more reasonable rate.
MP3
Tue May 19, 2020 7:34 am quote
Thank you for your generous offer. I will bookmark this page and if necessary get back in touch with you.
Tue May 19, 2020 9:18 am quote
Please up your reading comprehension - wentwest wasn't asking a question, he/she was answering the OP.
Tue May 19, 2020 9:34 am quote
Hey it was 0600 and I was still waking up at my desk at work.
And why is the site on central time? Just noticed that.
Tue May 19, 2020 9:37 am quote
Time setting is in your Profile....
Tue May 19, 2020 9:51 am quote
Checking, bet it is a Day light saving tome thing.
Yep, site time doesn't change so my time was off. Thanks
Tue May 19, 2020 12:26 pm quote
Personally I think the gonzo tweek is a very easy fix to apply, any half decent tool guy should be able to do it with very little problems. The hardest part is finding the 8 screws for the front nose cone lol. If you were here I'd do it for a can of Dr pepper.takes around 30 to 40 minutes to do.
Piaggio MP3 ie 400
Fri Jun 12, 2020 4:28 am quote
I don't think anyone can advise you on what to do, as this will depend on what you want. I bought MP3 400ie, 2009 (used) as I thought these scooters will be more stable in a rainy weather, and will be safer, as I wanted to ride in a rainy weather, what I found out from experience riding it is that it handles the same a two wheel scooter so I did not get the benefit I wanted. Before I bought it, I was aware that there is increase in the maintenance costs (double the amount) for front wheels and brakes and the steering bearing maintenance, so this was not a surprise to me. I don't regret buying it, but if I went back in time and I knew that there is no difference when riding in the rain, I would bought like a Yamaha Majesty or similar. I need to do the steering bearing maintenance now, one of the dealership mechanics told this scooter is too heavy for the motor size and I should ride it and try and sell it, it is not worth to spend money on it, but after I thought about it, if I sell it with the steering bearing not done, I will sell it cheap, and if I want to buy other scooter (second hand), I may not find one that is as good as mine (not other MP3, Yamaha most properly or Suzuki), I will pay more than the maintenance, and then there is a risk of find out other new issues in it, so I decided to do the steering bearing maintenance, already called Piaggio Dealership and they ordered the part, just waiting for their call to take it to them.
So this will depend on you, what do you want? sit down, have a cup of tea or coffee and think it over and do a bit of math, if you sell yours now, how much would get for it, buy other one, will it be a 3 wheeler or 2 wheeler, do you want to pay the maintenance cost for a 3 wheeler etc... then decide.
Good luck.
MP3 400 "Merlin"
Fri Jun 12, 2020 2:42 pm quote
That seems high. A dealer in Cleveland quoted me about $500 to replace my bearings. We opted to try the Gonzo tweak first before dropping the money and having to take the bike 2 hours from home and leaving it for a week.
Team Scooter Trash for Petfinder Foundation   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.2462s ][ Queries: 25 (0.0780s) ][ Debug on ]
