MP3 500 sport ABS loom
Piaggio MPE 500 Sport 2015
Tue Jun 02, 2020 9:43 am quote
I inadvertently cut through the front ABS sensor (don't ask long story).....Anyway I've got a new loom on order and would like to know what plastic work needs removing to re-connect, i can see it goes inside the leg shield but no idea where it goes from there ??
Tue Jun 02, 2020 10:20 am quote
It isn't possible to just splice in a bit of wire?
Gilera Fuoco 500ie
Tue Jun 02, 2020 10:21 am quote
allmost all
Tue Jun 02, 2020 11:17 am quote
Just solder the wires back together.
2015 MP3 500 ie Business
Tue Jun 02, 2020 11:48 am quote
Soldering iron and heat shrink tubing is all you need.
Tue Jun 02, 2020 3:15 pm quote
yup just repair it. they also make connectors you just stick wires in and het with a hair dryer and it melts the solder and heat shrinks all in 1. no need for a soldering iron and separate heat shrink.
Wed Jun 03, 2020 9:24 am quote
Thanks for all your replies guys, very much appreciated.
Obviously i'd solder the wires had there been enough length to solder, the wires where cut right at the point where the wires go into the sensor so difficult to wire when you've only got 1mm to play with.
Haven't had an answer as to what plastic work needs taking off so your advice would help.....
Wed Jun 03, 2020 9:32 am quote
Re: MP3 500 sport ABS loom
Possible to cut the connector you need off the new loom? Seems a shame perhaps but to me it would be a lot less work to cut that one part off, and splice it in your existing loom.
Wed Jun 03, 2020 3:54 pm quote
this is exactly what I would do.
Gilera Fuoco 500ie
Sat Jun 06, 2020 11:15 am quote
Thanks Guys, i've got the new loom and all i need to know is what plastics need removing ?
Gilera Fuoco 500ie
Sun Jun 07, 2020 4:09 am quote
allmost all the middle section won't come of when you leave the back
Sat Jun 13, 2020 12:07 pm quote
Thanks for all your help guys really appreciated.........Guess what ?? going to splice the new into the old, taking off all the plastic is hassle I could well do without !!!!!
On another subject, has anyone had any issues with a flappy passenger foot pegs ? i assume these are supposed to be spring loaded ?? my right hand side one doesn't go back into position flaps around everywhere !!
Tue Jun 16, 2020 12:03 pm quote
You are soldering the connections, right?
Make sure to get good connections. ECU's don't like resistance on wires.
Rallies Europe 2016   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1384s ][ Queries: 25 (0.0323s) ][ Debug on ]
