Dellorto PHBL24 carb help
Vespa PX200
Thu Jun 11, 2020 11:47 am quote
Just when I thought the carb was fine on my dad's small frame it has decided to play up again.
I took it out for a test ride after getting it just about right and rideable then suddenly it doesn't want to play any more. I can kick it and it idles lovely but any more than a slight hint of throttle and it dies.
I've tried turning the mixture screw 1/4 either way but the result is the same so I'm thinking a clogged jet or maybe the float stuck?
Any pointers or starting points much appreciated
Thu Jun 11, 2020 12:33 pm quote
That carb is pretty easy to work on. Just pop off the float bowl and take a look, squirt some carb cleaner through the jet stacks, make sure the float goes up and down and isn't full of fuel, the floats can break/degrade and fill and no longer float.
Vespa PX200
Thu Jun 11, 2020 1:30 pm quote
Thanks mate I'll get it off tomorrow and have a look. Agreed they are very easy to pull apart, not much to them at all and it was running fine so must be something fairly simple
Vespa PX200
Fri Jun 26, 2020 5:41 am quote
Dug this lot out of the float bowl and main, you reckon it's why it wouldn't run?!
Fri Jun 26, 2020 6:44 am quote
Roll it up and smoke it and see what happens.
Vespa PX200
Fri Jun 26, 2020 9:15 am quote
It definitely looks like a little bit of kush
I won't be trying that though
Fri Jun 26, 2020 7:20 pm quote
Looks like some "gas" to me.
Vespa PX200
Sat Jun 27, 2020 12:38 pm quote
It lives!
Now to get it somewhere near where I had it before...
Anyone know roughly how many turns to wind the fuel and idle screw out as a base setting on a PHBL? Just trying to save myself some time
Land of 10,000 Scoots Rally   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1992s ][ Queries: 27 (0.0472s) ][ Debug on ]
