2003 ET4 Liberty Engine Malossi 187cc Cylinder Kit
2010 S50 Modified "Punkin"; 2003 ET4 150 "ISO"
Thu Jun 25, 2020 4:42 pm quote
Greetings:
Getting ready to pull the trigger on this upgrade. At least one reliable source tells me that installing the kit limits the engine to "only" 40,000 miles, at which time the lower end bearings lose their will to live. Now the sun may explode before I get ISO to that mileage, given the short-distance rides I make to the Post Office and dry cleaners here in Deepinnaharta, but has anyone experienced even earlier premature failure as a result of installing the Malossi kit?
I really don't NEED the extra power, as opportunities to exceed 60 MPH here are infrequent, but the idea of being ABLE to take to the highway and cruise at 70 (I have the aftermarket primary gears...) is attractive, as are the bragging rights of nudging up to GTS-level top speeds. Still, I am pleased overall with the performance of the 150 as delivered, with the Aftermarket clutch, variator and (soon) the SitoPlus exhaust. I have the money, I have some time occasionally to perform the cylinder swap. Lord knows I need the Garage Therapy. Anyone with a reason to talk me out of this?
Thu Jun 25, 2020 5:31 pm quote
I will not talk you out of it.
Install and be delighted.
-g
2014 Commuter BV350(44,000)/2015 Scoot Life BV350(10,000)/2010 El Diablito SH150i(29,000)
Fri Jun 26, 2020 1:44 am quote
I've been running Malossi (no BBK for the BV) for about 35,000 miles. Wouldn't want to ride a stock set-up. Did you buy it for the resale value?
Go for it Turn some heads
Fri Jun 26, 2020 3:24 am quote
I don't own a Vespa - but is an ET4 the "small frame" version?
With 10" wheels?
And shorter wheelbase?
And no one here is concerned about your plan to go cruising at 70MPH?!
Bad form, here, to do so...I guess.
LX190, Primavera
Fri Jun 26, 2020 3:30 am quote
With 10" wheels?
It's the precursor to the LX. You don't actually gain much top end speed with the upgrade but you get there a hell of a lot sooner.
Mon Jun 29, 2020 4:37 pm quote
Greetings:
One iteration of Flash - 2001 Honda SA50 - features a 51mm x 44.4 90cc ministroker engine. It touched 80 MPH on 90/90 x10 wheels. This scooter weighs a full 100 pounds LESS than either Vespa.
Stability INcreases as speeds rise, though 95mm DRUM brakes at each wheel compelled discretion. In what was perhaps a stroke of good fortune, I managed to hole a piston with a rookie jetting error.
Not really worried about top speed, but the holeshot through traffic is more important.
Your Rally Here   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1505s ][ Queries: 27 (0.0382s) ][ Debug on ]
