Brake switch/lights
'81 Vespa P200e, '93 Vespa PX125e
Fri Jun 26, 2020 10:46 am quote
Hey all,
I have an 81 p200e. Just wondering: is the brake light supposed to light up when I squeeze the front brake? It comes on when I hit the rear brake.
Currently: the brake light does not come on when I hit the front brake.
Insight and help is always appreciated.
Cheers.
Fri Jun 26, 2020 12:48 pm quote
If the front brake is currently wired up to the brake light, then it will work. If it's not hooked up, then it won't turn on your brake light. Remove the headset to check to see if you have a front brake light switch under it.
Fri Jun 26, 2020 2:29 pm quote
Fair enough. It seems like what youíre saying is that the front brake is supposed to turn the brake light on, yes?
Fri Jun 26, 2020 2:34 pm quote
The US market P should have a front brake light switch thatís located underneath the headset. Lots of the time the owner will just bypass the switch when replacing the front brake cable. So while the wires may still be there, the switch itself might be missing.
Fri Jun 26, 2020 2:38 pm quote
Ok. That works. Now what if itís a European p2?
Fri Jun 26, 2020 3:29 pm quote
It's probably the exact same for the Euro P's as well. You just have to remove the headset cover to find out what's going on under there...if you're desiring to have a front brake light switch. Otherwise i'd just leave well enough alone.
Jet Eye Master
Sat Jun 27, 2020 8:13 am quote
A UK 80's P200E would only have rear. Does it have a battery? UK ones didn't have those either.
Sat Jun 27, 2020 9:17 am quote
Yes, Jack.
No battery.
Maybe thatís why?
P Series / Li / LML / Motobi
Thu Jul 02, 2020 5:45 am quote
+1
none of mine did, until i fitted them....
2007 Stella 150
Thu Jul 02, 2020 6:07 am quote
Why would you not want the person behind you to know your slowing or stopping? Really curious why a company would not put in a front brake switch.
Thu Jul 02, 2020 6:23 am quote
it wasnt made mandatory till after 1986, when indicators also became mandatory in the UK
2007 Stella 150
Thu Jul 02, 2020 11:17 am quote
Did you use all hand signals?
Ď60 VBB
Thu Jul 02, 2020 4:34 pm quote
Always use the rear brake, no issue.
Thu Jul 02, 2020 11:52 pm quote
We were and are meant to if we drive them without indicators..... although i am yet to see anyone who does!!
https://www.drivingtesttips.biz/wp-content/uploads/2014/05/driving-hand-signals-574x176.jpg
Rallies Europe 2016   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1627s ][ Queries: 25 (0.0550s) ][ Debug on ]
