Clutch Cable out of Left or Right Side of Frame Headset Tube
Sat Jun 27, 2020 2:53 am quote
Facing forward over the frame, which is your preferred cable routing for the clutch cable out of the frame headset tube, the right side or the left side? Why?
bare metal cafe racer
Sat Jun 27, 2020 3:32 am quote
Left. Because they are meant to. Robot says so.
Sat Jun 27, 2020 4:05 am quote
True, in the parts books it shows it always coming out the left side hole. However, I've read (here and other places) that the right side allows a smoother, more gradual curve into the headset and clutch lever. I'll count the votes, consider the reasons, and then decide.
74 50s x3 78 P200 84 Cosa PK50XL2 58 AllState 68 Sprint 80 50special '66(?) Super125
Sat Jun 27, 2020 5:38 am quote
Rebel
I go down the right side whenever I can for the reasons you just described, I vote right side
Sat Jun 27, 2020 6:36 am quote
Re: Rebel
I have also heard that the electrical harness and throttle cable must/should go behind the lock barrel. The Scooter West dudes in the video also pointed that out. What is the issue with putting the electrical harness and throttle cable in front of the lock? Is it possible that the cable could get wedged between the lock barrel and the slot in the fork?
Do you put the clutch cable behind the lock along with the harness and throttle cable or in front where there is more room?
Sat Jun 27, 2020 6:39 am quote
Actually radius of bend will be bigger coming from the left. Try it. See it.
Sat Jun 27, 2020 6:40 am quote
Isn't it a tighter radius though?
Sat Jun 27, 2020 6:53 am quote
Is this a negative thing or a positive thing?
Sat Jun 27, 2020 7:30 am quote
From the left, bend begins in headset "neck" giving something approximating 5" radius.
From the right, bend can't start until close to the height of the top of the steering column, giving a 2" radius.
Try feeding the cable housing down from the handle just 8" or so into the frame on either side. Compare the bends. Obey your Robot.
Sat Jun 27, 2020 5:11 pm quote
Ok, thanks. It makes sense.
P Series / Li / LML / Motobi
Sun Jun 28, 2020 8:26 am quote
i put gear cables on the left hand side of the headset
throttle and gear on the right hand side.
Sun Jun 28, 2020 11:59 pm quote
Could you clarify that? I'm not sure I understand.
'63 VBB2T - '76 Sprint V. - '86 PX200E - '18 300 GTS Super Notte
Mon Jun 29, 2020 12:47 am quote
This is my order:
From left to right:
Left hole:
Gear cables
Clutch
Right hole:
Throttle
Wire loom (picture doesn't show it, but inside it goes between throttle cable and lock).
P200 PX150
Mon Jun 29, 2020 7:50 am quote
Just had this chat with Greasy recently...
I went with the same as above
L. ----->>> R
Gear, gear, clutch. Loom, throttle
58 VB1T, 68 SS180, 81 100 Sport
Tue Jun 30, 2020 6:06 pm quote
I'm facing the same dillema with smallframe '81 100 Sport. Is the positioning of the cables and/or harness different than suggested above for the Large frames?
The photo below is from when I tore down my 100 Sport, but I cant tell if the harness comes up in front-OR-behind the steering lock.
Also need confirmation that the throttle should be in the far front, as shown; or if it should be just behind the steering lock? As suggested for the LF. I cant confirm that what I had when torn down was correct per factory specs.
Thanks!
As it was when I tore it down many moons ago...
Tue Jun 30, 2020 7:16 pm quote
I can't remember what I did on my small frame headset wiring and cables. I'm afraid to touch the headset on that thing now because I vividly recall the pain and frustration of getting that headset in place and working. Even fiddling with the headlight is a nightmare. I love riding it, but it's the only bike I have that I truly dislike working on.
Tue Jun 30, 2020 7:51 pm quote
I totally understand that feeling. Everything is just...small.... HA
Cross Egypt Challenge - A 2400km ride throughout Egypt   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.1599s ][ Queries: 25 (0.0316s) ][ Debug on ]
