Hi,
Selling a very clean white Vespa top case and chrome rack that was mounted on my 2017 Vespa GTS 300. It comes with two keys and all mounting hardware for the rack.
It's in perfect shape other than the following. 1) It does not have the Vespa logo on the back. 2) It has two small holes drilled into the bottom of the case where I had mounted an Admore light bar frame. See photos. These can easily be taped over or filled in.
It has some 3M Solis reflective tape on the back, which can be removed. These cases are designed to work with a variety of racks. To use the rack that works on the GTS you must cut off some of the plastic mounting tabs underneath. That was done cleanly with a Dremel. I also added some adhesive backed felt to the inside case lip in order to silence the rattling that can occur between the lid and the case while going over bumpy roads. The photo of the rack shows it mounted on my current GTS and the duct tape you see has been removed.
Asking $200 for top box and rack, shipped to lower 48.
Please PM with questions.
Thanks,
David
