How to Bypass the Kill switch?
2009 MP3 400ie
Mon Jul 06, 2020 2:27 am quote
hello mates, I experienced no ignition on the way home, nothing happens when I push ignition switch.. but when I played with the kill switch it worked. it seems my kill switch is going bad and there's no stock here. need to bypass it for the meantime so I can go to work.
50cc Beo, BigBeo
Mon Jul 06, 2020 5:14 am quote
No problem, you may simply short it.
2009 MP3 400ie
Mon Jul 06, 2020 5:23 am quote
sorry im not good at electicals... how will I short it?
Mon Jul 06, 2020 6:08 am quote
Take the switch out, there will be two wires going into it.
Tie these two wires together so they have good solid electrical contact.
Mon Jul 06, 2020 6:48 am quote
Use a paperclip. Wrap some tape around the whole thing to keep the terminals from sliding off the paperclip.
Gilera Fuoco 500ie
Mon Jul 06, 2020 9:37 am quote
a paperclip will burn out
a new switch is only 8 bucks and sold on Aliexpress for less
most vespa and piaggio models use the same one
Mon Jul 06, 2020 4:35 pm quote
What on earth makes you think that? There's bugger-all current going through the kill switch, it's just a voltage signal into the ECU (or the dash for the engine off).
On the 400, there are three wires.
You need to join the Green/Black to the Grey/Green, and leave the Orange/Blue open circuit (not connected to anything but unable to short out to anything).
2009 MP3 400ie
Mon Jul 06, 2020 5:00 pm quote
Thank you Jimc
Mon Jul 06, 2020 5:22 pm quote
Just a question. Don't most kill switches switch to ground? So shorting the wires at the switch will have the opposite effect.
Just so we know.
Mon Jul 06, 2020 6:12 pm quote
They vary between all models and years. Some have four wires to them, some have three (like this one according to its circuit diagram) and some merely two.
They all work in different ways, depending if they're carb'd, fuel injected, US spec or EU or Indian/Vietnamese.
Old-school 2-stroke machines killed the engine by shorting the CDI signal to ground. Modern FI 4T ones just 'instruct' the ECU to kill the engine - in a fail-safe way.
Mon Jul 06, 2020 6:16 pm quote
OK just so the OP can test his paper clip before reassembly.
I didn't find a wiring diagram without joining or login in or,or,or.
Yes one Primavera wiring diagram says one wire the USA 3v version says 2 wires.
Mon Jul 06, 2020 6:27 pm quote
Just for the record anyone reading this who has a Primavera 4T there is only one wire going to the switch and it is grounded to stop. "Run" is open circuit.
That is SO completely different to an MP3 400 that I have no clue why you are posting *your* experience.
Did you look at the MP3 400 circuit diagram to see it it was similar to yours? No? In which case WTF have you suggested your kill switch wiring is in any way similar?
Sheesh.
Mon Jul 06, 2020 6:36 pm quote
Just wishing to clarify. Not everyone on here knows butkis about which they talk.
It is a forum not an outlet for your superiority, Sheesh
I noticed you didn't post a picture of said wiring diagram that i already explained i cannot easily download.
Mon Jul 06, 2020 7:10 pm quote
Here is a MP3 400 kill switch if it helps anyone.
From... https://manuals.wotmeworry.org.uk/Piaggio/Piaggio%20MP3/MP3%20400/
Mon Jul 06, 2020 7:17 pm quote
And the Primavera 3 valve if it helps.
From... https://manuals.wotmeworry.org.uk/Vespa/Primavera/
Tue Jul 07, 2020 9:50 am quote
waspmike wrote:
I didn't find a wiring diagram without joining or login in or, or, or.
For future reference, the diagrams posted above came from manuals/diagrams accessible through the Wiki section of this website.
Tue Jul 07, 2020 11:50 am quote
If you've missed their existence in the last 10 years you've been a member or not noticed the 'www' link under my sig - well I'm sorry I can't help you there. There's no membership or fee needed to access them.
Tue Jul 07, 2020 1:58 pm quote
Are you the only one responsible for keeping these amazing manuals online and accessible? Serious question, I'm new here.
Tue Jul 07, 2020 4:48 pm quote
yes he is.
Tue Jul 07, 2020 4:53 pm quote
old as dirt wrote:
yes he is.
I'm missing loads of manuals for the scooters that came out in the last few years - so anyone who has one that's missing in pdf form, please feel free to email it to me. No restriction on size. (though there might be a limit in the chain at about 4TB)
Tue Jul 07, 2020 4:55 pm quote
old as dirt wrote:
yes he is.
So when he dies all the info does too? I hope he is very young and healthy!
Tue Jul 07, 2020 4:57 pm quote
S.Ro wrote:
old as dirt wrote:
yes he is.
You can always download the lot and host it yourself if you wish.
Tue Jul 07, 2020 5:04 pm quote
jimc wrote:
S.Ro wrote:
old as dirt wrote:
yes he is.
You'll probably live longer then me.
Thank you for doing what you do!
Wed Jul 08, 2020 11:32 am quote
jimc wrote:
old as dirt wrote:
yes he is.
Will be ordering a full set of 2020 Sei Giorni manuals in .pdf format here soon and will pass them on to MV.
2009 MP3 400ie
Mon Jul 13, 2020 1:39 am quote
Thanks Jimc followed your instructions.. it worked. many thanks
2019 MP3 hpe 500 sport Advanced " Missy "
Tue Jul 14, 2020 2:19 am quote
He could probably find a used one over ebay for less. No garatee though.
2016 Sprint S 150 (his), 2016 Sprint 150 Blu Gaiola (hers), 2006 GTS 250 Excalibur Gray (hers), 2006 GTS 250 Black (his), 2012 Kymco Downtown 200
Tue Jul 14, 2020 3:54 am quote
The kill switch is a safety feature and I would be very reluctant to bypass except for a short period of time while a new one is being procured.
Also, here in VT and I suspect elsewhere in the USA, that switch is tested during yearly inspection, so the scoot would not pass with it not working.
Tue Jul 14, 2020 5:32 am quote
Never had anyone test my kill switch during inspection.
Piaggio MP3 500
Wed Jul 15, 2020 6:06 am quote
Here in Texas, the inspection is:
Drive up to the yellow line and stop. Blow the horn. Done, pay your $7.
You should have seen the inspector jump when the Stebel horn went off
Fri Jul 17, 2020 5:56 am quote
You have a Stebel horn on your Roller Squeazel? You are evil
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.3125s ][ Queries: 27 (0.0869s) ][ Debug on ]
