“Check expansion tank cap efficiency”
Mp3 500 2010
Tue Jul 07, 2020 11:05 am quote
I’m checking parts of my cooling system after a leak to be sure everything is good and right, but apparently af1 and scooter west, and the web, can’t tell me how to check my cap, the manual states it should be at .9 bar and it should allow air inlet during the cooling step. So please someone tell me how? It’s a cheep part but I hate to replace something because I can’t test it
Tue Jul 07, 2020 11:11 am quote
You use a coolant reservoir cap pressure tester.
Not sure you are going to find one that has an adapter for the Vespa/Piaggio cap though.
Mp3 500 2010
Tue Jul 07, 2020 11:32 am quote
Thank you! I’d stark looking for one but I don’t have the slightest idea where to start
Tue Jul 07, 2020 11:45 am quote
Have you got excess pressure? You'd know this if coolant started steaming out of the cap (yes, it'd become steam as soon as it dropped in pressure on exit).
No steam - you've not got excess pressure, your cap is fine.
If there's a leak, just check all hose connections. If they're OK, it can be the expansion tank itself that leaks from a split seam. If that's OK, check for white smoke when you first start the engine - if there's excess (not just the normal mist from overnight condensation) then you may have a split in the head or head gasket.
Mp3 500 2010
Tue Jul 07, 2020 11:52 am quote
Hayyyy thank you Jimc that’s super helpful, I guess my cap is fine, I only had my water pump cover o-ring go out so I’m replacing it(it looked a little shabby) I do know how I’ll likely need a new water pump I just thought I’d try the new o-ring, say Jimc do you know if the o-ring needs any sealant? I know that manual says no, but when I opened my bike up the o-ring had a thin white grease feel to it, I wasn’t sure what that was about, again thanks
Tue Jul 07, 2020 4:56 pm quote
No sealant needed. Be *very* gentle with the screws.
50cc Beo, BigBeo
Wed Jul 08, 2020 10:22 am quote
I've overheated my mp3 recently on a kinda offroad forest road Well, mp3 puked some coolant on a stop. I didn't have a chance to find where it is from: a hose, a hose clamp, from cap or whatever. The good part is that it remained dry on a tarmac and didn't overheat on my way back home.
And unfortunately it was not any kind of steam.
Thu Jul 09, 2020 12:15 am quote
Jah, make sure your coolant fan is working. You shouldn't be losing any coolant.
50cc Beo, BigBeo
Thu Jul 09, 2020 8:50 am quote
Yep, it works indeed. Even more strange thing is that temp gauge wasn't overfilled.
2015 MP3 500 ie Business
Thu Jul 09, 2020 3:02 pm quote
Just out of curiosity, how do you "overfill" a temp gauge???
50cc Beo, BigBeo
Thu Jul 09, 2020 6:58 pm quote
Just as anything else, in two steps: first you fill it up to top, and next you add one more drop.
Indeed I mean that it didn't reach its maximum reading.
Cross Egypt Challenge - A 2400km ride throughout Egypt   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.1369s ][ Queries: 27 (0.0363s) ][ Debug on ]
