2016 mp3 300 lt engine cuts out on 100kmh
mp3 300 lt 2016
Tue Jul 14, 2020 2:17 am quote
Hey Guys
I just got a 2016 mp3 300cc LT with only 10,000 km.
After replacing the oil and water i hit the freeway and suddenly lose power (while driving 100-110 km/h).
engine has turned off.
i let it rest for 4-5 minutes and start it again, it starts and i drive back home.
Since then it happen to me 4-5 times in varying frequency (once a week on once a month).
any ideas ?
thanks in advance.
mp3 500 2018 (USA-version)
Tue Jul 14, 2020 6:55 am quote
1. The problem is electrical. Lack of spark. 2. Lack of fuel. A possible problem is in the fuel pump .... What is the air temperature when a stop occurs? 3. Thermal damage to the piston. Unlikely. Not excluded.
4-5 minutes to not start?
Tue Jul 14, 2020 7:25 am quote
Possibly a heat related failure? Try some freezer spray on the ECU, or coil next time.
2013 MP3 300ie
Wed Jul 15, 2020 11:09 am quote
Re: 2016 mp3 300 lt engine cuts out on 100kmh
gaigo wrote:
Hey Guys
thanks in advance.
Did you bleed the air from the cylinder head after replacing coolant?
mp3 300 lt 2016
Mon Jul 20, 2020 10:55 pm quote
4-5 minutes.
true. 4-5 minutes.
the air temperature here is high - about 30C.
right after it cuts off i still have power, lights are on and i can lock the front suspension as it get slow.
might be a fuel pump problem or lack of spark but then why can't i start the engine right away....
2015 MP3 500 ie Business
Tue Jul 21, 2020 2:09 am quote
Was the coolant replaced/renewed at some point, and if so was the bleeder valve on the cylinder head used?
These engines do not self bleed and if a coolant service was performed without bleeding manually, you will have a pocket of air inside the cylinder head that will give you similar issues when the engine reaches higher revs for prolonged stretches
2013 MP3 300ie
Tue Jul 21, 2020 2:49 am quote
gaigo wrote:
Hey Guys
any ideas ?
thanks in advance.
That was my first thought also...
Tue Jul 21, 2020 7:01 am quote
sounds like vapor locking. do a test ride and when it happens open the gas cap and if you hear a big woos of air you have a venting issue. Also if that happens you should be able to restart the scoot again right away.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1326s ][ Queries: 25 (0.0340s) ][ Debug on ]
