Tilt lock and horn.
MP3 250
Sat Jul 25, 2020 5:57 am quote
Hi all.
All of a sudden my horn repeatedly sounds when I engage my tilt lock. Seems odd. Anyone had that happen. Shall I just disable the horn?
2015 MP3 500 ie Business
Sat Jul 25, 2020 8:47 am quote
No, do NOT disable the horn. It is informing you that there is a serious issue.
Have you checked the fluid level of the tilt lock system?
Has the bike ever had any fluid leaks at the front end?
Do you regularly park the vehicle long term (more than a couple of hours) using only the tilt lock system?
And has the bike had a tilt lock service i.e. fluid flush and renewal?
MP3 250
Sat Jul 25, 2020 8:52 am quote
Had the tilt lock done about 12 months ago. I have not sued the tilt lock for about 4 months and always use the stand as the connector got damaged. I have read that it not to hard to replace the fluid. Just a question what fluid do I use?
MP3 250
Oh and no leaks whatsoever.
Sat Jul 25, 2020 11:15 am quote
IF there are no leaks, then the problem lies elsewhere in the tilt lock system such as stuck motor, cable damaged/broken, pressure sensor, wiring issues, etc.
DOT4 is the spec for the tilt lock, same stuff as for the braking system
Gilera Fuoco 500ie
Sat Jul 25, 2020 12:28 pm quote
air in the system
MP3 500, GTS 250 (both 2008 MY), 2012 Honda NC700 DCT, 2014 Can Am Spyder RT
Sat Jul 25, 2020 12:51 pm quote
Or a small leak in the pressure switch.
Gilera Fuoco
Fri Aug 21, 2020 6:04 am quote
If you EXACTLY have no pressure problems in the tilt lock system and you cannot quickly replace the pressure sensor, you can use the solution from the next topic and remove this relay:
MP3 500 Horn Alarm goes off every time I turn it on. WTF!?! (Page 3)
MP3-250ie, Vespa GT200L
Sat Sep 26, 2020 5:00 am quote
One other thing to check...
I had a similar issue a when I first bought mine and the previous owner cut the price because they could not fix it either.
It was down a little fluid but not much. Filling it did not resolve it. Then I read(maybe here) - never use the tilt lock AND stand at same time.
I took it off the stand - still happened, then I thought like an engineer for a minute.
Take it off the stand
Start it
Turn off the tilt lock
Tip one side, then the other as far as you are comfortable holding it. Do left/right lean a couple of times
Turn it off and restart.
Now it only happens to me when I forget and use both.
MP3 350
Fri Apr 02, 2021 6:21 am quote
Start it
I'll give it a try.
2009 MP3 400, 2004 Honda ST1300
Sat Apr 03, 2021 3:25 am quote
I'm not sure why this would have any effect. There are no angle sensors that I'm aware of.The system is free floating left and right.
  DoubleGood Vespa T-Shirts
[ Time: 0.1777s ][ Queries: 38 (0.0672s) ][ Debug on ]
