New regulator
1980 P200E - GT 200 L - 2005PX150
Sat Jul 25, 2020 9:19 am quote
Guys, just got the new regulator. Not sure of the wiring location. Lettering is different
2005 PX 150
Thanks[/i]
Sat Jul 25, 2020 9:20 am quote
2
3
1963 VBB2T
Sat Jul 25, 2020 10:08 am quote
I won't even attempt to try to give you a correct/incorrect answer, I went through this wiring up my vbb with a 12 v dc . I basicly just did what I was told
Take a look and see if this helps wiring help needed
1979 P150X, 1983 P200E, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Sat Jul 25, 2020 12:51 pm quote
Problem solved
Sat Jul 25, 2020 12:55 pm quote
Meaning?? If you indeed used this regulator, you should know that it will be emptying your battery, cause on your circuit it acts as lets say a "coil" that will be constantly drawing power from it...
Sat Jul 25, 2020 1:20 pm quote
Itís a 5 wire regulator, same as the old one.
Sat Jul 25, 2020 1:22 pm quote
The fact that it's a 5 pin regulator doesn't mean it's the proper one for your scooter. The letters are different for a reason. These two regulators work differently...
Sat Jul 25, 2020 1:39 pm quote
The only 5 pole reg I have seen are for the Stella and for the PX 150. This is for the PX
Sat Jul 25, 2020 1:50 pm quote
PX wiring looms came in many variations and cause of that there were two different 5 pin regulators. You have the wrong one for your PX / wiring loom / circuit. Again, the letters on the terminals are there for a reason. The double "A" regulator on your PX will be emptying your battery overnight...
Sat Jul 25, 2020 1:59 pm quote
Safis is so right about draining your battery and vice versa. The newer PX regulator will drain a battery in an older P200E, too. I know cuz I had a new PX regulator on my P200 and the battery just drained. All other lights worked fine. You definitely have a older P200E regulator. I think you can make it work by changing the stator wiring or running without a battery but not worth the time.
Send me a PM and I'll send you my newer PX150 regulator with double G's for postage. It's from the east (Middle East or Far East) so quality maybe questionable but if it works, great.
Sat Jul 25, 2020 2:16 pm quote
And the wires are wrongly connected, even on your old regulator. You have mixed up the wires between the regulator and the flasher. Maybe that was your problem all along??
Regulator
G: Blue
G: Green / Yellow
B: Red
C: White / Red
▼: Black / Ground
Flasher
Green Dot: Double Green
Red Dot: Red / Black
White Dot: White
Sat Jul 25, 2020 3:01 pm quote
This is the one I installed
Sat Jul 25, 2020 3:13 pm quote
I give up...
Sat Jul 25, 2020 3:18 pm quote
Regulator
G: Blue
G: Green / Yellow
B: Red
C: White / Red
▼: Black / Ground
Flasher
White Dot: White
Good catch Safis. Based on his 1st pic the blue wire and green wire should be switched.
Try changing those blue and green wires in the old regulator and see what happens. Your problem maybe solved. Regardless, that new reg you got won't work and no one has the correct wiring substitution for the different letters. But if you want, go ahead and install it with a charged battery. Time will tell you if that regulator would work.
Sat Jul 25, 2020 3:23 pm quote
Not only those. He has also mixed up the flasher wires with the regulator's and I bet that's the reason he gets no charging. Pay attention to the +B & C terminals. He has the Red / Black & White wires that should be on the flasher and the Red & White / Red that should be on the regulator are on the flasher...
My previous post with the diagram tells the correct order...
Mon Jul 27, 2020 6:46 pm quote
I'll work on the wiring tomorrow. So far, no issues with the electric start. Horn is a little weaker.
Tue Jul 28, 2020 4:31 am quote
Well, I switched the blue and green/yellow wires and reused the old regulator. Guess what, it works!!!!!
Now, I switched the wires on the flasher and regulator as mentioned above, and it blows the fuse. WHY????
Tue Jul 28, 2020 6:29 am quote
Yeah, scratch that. Apparently the US model PX has the wires connected differently. So, apart from the first two wires you already switched, the others were OK. I donít understand why they did this change when Piaggioís wire coloring is pretty much the same even on their latest models...
https://www.scooterwest.com/wp/wp-content/uploads/2018/09/PX150-USA-WIRING.pdf
Tue Jul 28, 2020 7:06 am quote
Grazie
Missouri Loves Company Rally   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1666s ][ Queries: 27 (0.0294s) ][ Debug on ]
