Oil problem
1980 P200E - GT 200 L - 2005PX150
Sat Jul 25, 2020 12:53 pm quote
Got my 2005 PX 150 started, and surprise; oil everywhere? What is the problem?
Sat Jul 25, 2020 12:54 pm quote
2 oil
3 oil
Sat Jul 25, 2020 2:04 pm quote
If bottom carb box or anything below that is not wet, start looking at that rear axle seal or clutch cover. Need to remove the rear wheel to see whats going on.
Sun Jul 26, 2020 8:38 am quote
Here is where itís from
What is the cause?
Sun Jul 26, 2020 12:05 pm quote
Try permatex motosel to seal the exhaust when installing.
Honda elite
Sun Jul 26, 2020 2:13 pm quote
How is your fuel shut off? Reason asking the exhaust shouldnít have oil dripping out unless itís over jetted or something else.
Sun Jul 26, 2020 2:18 pm quote
I hope itís not the clutch Side seal
Kymco Downtown 300i
Sun Jul 26, 2020 4:37 pm quote
What is the cause?
That's the exhaust port?
Sun Jul 26, 2020 5:37 pm quote
I hope so
Sun Jul 26, 2020 6:39 pm quote
Col-
Oil on that side of the time wouldnít come from the exhaust, more like the clutch breather, cover or rear hub seal.
Clean the motor real good, dust it with baby powder and take it for a ride.
If you still suspect your clutch side seal, youíll be blowing billowing white smoke and starting will be more difficult up to the point the seal is toast. You can also check your gear oil for gasoline mixing with it.
Kymco Downtown 300i
Mon Jul 27, 2020 11:47 am quote
colosseo wrote:
I hope so
Is the picture with the fins in the background the exhaust port where the exhaust pipe and muffler attach?
Mon Jul 27, 2020 12:08 pm quote
Yes[/quote]
Kymco Downtown 300i
Mon Jul 27, 2020 2:28 pm quote
colosseo wrote:
Yes
[/quote]
It then looks like your oil injection pump is pushing way too much oil into the engine. Assuming you are still using oil injection the thing is probably stuck in the full throttle position.
Cross Egypt Challenge - A 2400km ride throughout Egypt   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.1530s ][ Queries: 27 (0.0314s) ][ Debug on ]
