Piaggio MP3 400ie 2009 front wheel size change |
Post Reply Forum -> MP3 Discussion |
Author | Message |
![]() Hi all - has anyone had any experience in or know of anyone who has changed the 12" Piaggio front wheels on a 2009 Piaggio MP3 400ie to 13" ? I'm curious to know if it is possible and if so is it a matter of simply taking off the 12" and bolting on the 13" wheels ? In the attached, I currently have the 12" and am wanting to fit the 13" that come from the 500 MP3. Thanks all.
![]() As far as i know it's a straight swop as i did it on my fuoco and as everthing is the same wheel hub wise through the mp3/fuoco range go for it. It certainly looks better with the 13" and on both mine and 2 other owners who have done this on there fuoco's it make the handling of the bike better.
![]() Thank you, 3legsofman. When you did your change, were you able to use the existing mudguards for your 12" wheels ? and just swap the wheels ? or did you have to make mods to the 12" mudguards ?
![]() CRH wrote: Thank you, 3legsofman. When you did your change, were you able to use the existing mudguards for your 12" wheels ? and just swap the wheels ? or did you have to make mods to the 12" mudguards ? |
![]() Danger! The 13 inch hubs take 35mm stud, the 12 inch are 40 mm which bottom out before the 13 inch wheel is tight on the hub. A poor fix is to add 2 quarter inch washers to each stud. Better ask for 35mm studs or risk ruining the 13 inch rim.
![]() Iowatrike wrote: Danger! The 13 inch hubs take 35mm stud, the 12 inch are 40 mm which bottom out before the 13 inch wheel is tight on the hub. A poor fix is to add 2 quarter inch washers to each stud. Better ask for 35mm studs or risk ruining the 13 inch rim. |
![]() I found out a bit harder. With hearing aids in I could hear a squeak on left turns and could see tiny black tracks on the rim. When you see black around aluminum, look for trouble. The wheel suspended could move slightly on the hub. The dealer checked the parts books and found the shorter studs. I think the 12 inch rims are going back on. Not a problem since I just bought a new 500 HPE.
Too bad the 500 HPE Sport Advanced are not available here in the midwest. I would have liked the Gold color, maybe the reverse not so much. Piaggio may be a while ramping up production after Covid19. Bet I could buy one in Paris. I just cannot get there to ride it. |
![]() I realised when i was tightening the S/H cap screws that something felt wrong.
![]() My 13 inch rims were put on by a dealer. I should have checked them myself, as the dealer is mostly just Vespa with limited experience with MP3. It ran for months with the longer studs and the right side was still tight without additional washers.
There was another discussion on 13 rims where 12 inch were, but I cannot find it. Hope they also caught that shorter studs are needed. |
![]() Iowatrike wrote: I found out a bit harder. With hearing aids in I could hear a squeak on left turns and could see tiny black tracks on the rim. When you see black around aluminum, look for trouble. The wheel suspended could move slightly on the hub. The dealer checked the parts books and found the shorter studs. I think the 12 inch rims are going back on. Not a problem since I just bought a new 500 HPE. Thanks for any valuable insight in clearing this up for me. It seems like a well deserved risk for the ‘model upgrade reward.’ Thanks Greatly. Buying used or even new rims for any kind of vehicle is a can of worms, due to loose parts tolerance specs. Good luck with your new bike. |
![]() Since 3legs could fix the stud length problem with a 8 smellameter tap, there can not be too much difference. My dealer is just ordering shorter studs. The problem now is supply chain. Covid19 here and in sunny southern Italy has slowed up all Piaggio parts and scoots.
A moment of silence for all the people we lost to this pandemic. |
![]() We have very few MP3s here in the midwest flyover country. You need to find someone in France. They have half of the production of MP3s so I bet someone has tried the swap.
![]() oddjob1 wrote: Will the 125/300 cc 13" front wheels be ok for fuoco? |
![]() oddjob1 wrote: Will 13 inch front wheels with abs ring still fit on Gilera fuoco ? |
![]() MP3 400 with 13-inch Yourban front wheels. Fits perfectly, no need for mudguard change. Much improved ride safer leaning.
[ Time: 0.2957s ][ Queries: 47 (0.1146s) ][ Debug on ] |
