Leftt Cowl door latch
1963 VBB2T
Wed Jul 29, 2020 6:17 pm quote
Hey guys can I get some help, I need to put the new latch and lock on the small door on the left cowl and donít have a close up pic of the setup. Would someone be so kind as flip open your door and take a couple detailed pics of the slim latch and lock setup please? Iíll attach the parts I have .
Thanks appreciated.
[/b]
79p200e 66smallstate 85pk50xl 84p125ets 63GL150
Thu Jul 30, 2020 6:17 am quote
Here are some pics.
Should be similar.
Hope this helps.
FYI, I believe that for the lock you have, it wonít be possible to remove the key without locking the side box. Original lock could remove the key in both unlocked and locked positions.
1963 VBB2T
Thu Jul 30, 2020 6:50 am quote
Perfect thanks for the photos, helps a ton. Originally there was a wine cork where the round lock should have been
2007 Stella 150
Thu Jul 30, 2020 7:26 am quote
Red or white wine?
1963 VBB2T
Thu Jul 30, 2020 7:52 am quote
Red for sure . I still have the cork.
1963 VBB2T
Thu Jul 30, 2020 6:22 pm quote
Thanks poidog, got it done. Is there suppose to be some sort of bumpers between the door and the cowl? Can't see how metal to metal is right. I was sent the long pin to attach the door to the cowl but its too short to go all the way through , I'll have to come up with something there.
Vespa 150
Fri Jul 31, 2020 5:23 pm quote
You might want to keep the cork.
It's a glorious pain in the neck to require the key to get into that cowl or to shut the cowl. I keep oil and tools in there, and I have to lock the steering to open it or close it. It's a nuisance.
If I weren't so lazy, I'd have removed the lock or invested in a split key ring. I guess I'm a glutton for punishment.
If anyone knows a vendor who sells a retrofit lock that can be open and remove the key, I'm in. Extra points if the steering tube lock can be keyed alike.
Sat Aug 01, 2020 7:22 am quote
Glad you got it sorted out.
As far as I know, someone correct me if I am wrong, there was no rubber trim there. It is sold as an 'accessory' and can be put on.
bare metal cafe racer
Sat Aug 01, 2020 8:59 am quote
That door fits pretty tight as is and rubber would make it hard to close. Looks better without.
1963 VBB2T
Sat Aug 01, 2020 9:05 am quote
Yes when I sit the door in place it does fit nice and snug and I suppose when its latched it'l pull tight.
Cross Egypt Challenge - A 2400km ride throughout Egypt   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.2076s ][ Queries: 25 (0.0305s) ][ Debug on ]
