Plug look ok?
PX150
Thu Jul 30, 2020 4:01 am quote
Hi, does this plug look ok or too rich or too lean?
GTS 300 ABS, 2018
Thu Jul 30, 2020 1:13 pm quote
Looks pretty normal 2 stroke plug to me. They are a bit darker because of the burning oil.
Jet Eye Master
Thu Jul 30, 2020 1:59 pm quote
As a general plug it looks rich or too high a number. If this was WOT it's way over.
Thu Jul 30, 2020 3:19 pm quote
Looks too rich. There should be some tan.
BV 350
Fri Jul 31, 2020 10:33 am quote
Maybe
The only way to really read a plug is to run the engine full throttle for several minutes, then shift to neutral, kill the engine, and coast to a stop. Part-throttle and idle confuse the reading.
Unless mileage is a major concern, 2-strokes seem happiest running a bit rich. So long as you are not having problems with the plug fouling, I'd leave this one as is.
PX150
Fri Jul 31, 2020 10:54 am quote
[quote="kaukari"]
[quote="Jack221"]
[quote="yackee"]
[quote="Jimding"]
Thanks for the replies, great stuff. Yeah the reason I asked about the plug is that the bike starts ok and runs well enough but on open throttle it hits a flat spot and just gurgles. So my three questions to the experts are: what plug ideally should I be using (2000 PX150 engine) and with what main jet? And is it a mixture-screw issue to get rid the flat spot on open throttle?
Thanks again, cheers
GTS 300 ABS, 2018
Sat Aug 01, 2020 3:09 pm quote
Gurgling at fully (only ?) open throttle may result from too big main jet or too rich mixture. Easiest way is to try to adjust the mixture little bit leaner (more air) with the screw.
If this does not help, you need smaller main jet. I`d forget the plug. It has nothing to do with this issue.
Land of 10,000 Scoots Rally   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.1572s ][ Queries: 25 (0.0340s) ][ Debug on ]
