LX150 Final Drive Idler Gear Ball Bearings
Fri Jul 31, 2020 11:09 am quote
While debugging *why* things went bad in the post-engine drive train (and bad did happen, including needing a new clutch bell housing), I opened the rear end to insure that all looks good in there. I did notice the ball bearing assembly which holds the Final Drive Idler Gear seemed a bit grittier than the rest.
Before I "fix it until it is broken" - how difficult is it to pop out these bearings and reinstall new ones?
(although I would hate to put it all back together and send it to the shop, that is a possibility as well)
/HW
2008 GT200L
Fri Jul 31, 2020 11:37 am quote
It's simple and easy with the right tools. This past month, I replaced all those bearings.
I bought the Slide hammer set from Harbor Freight with a 20% off coupon.
Here: https://www.harborfreight.com/slide-hammer-and-bearing-puller-set-5-pc-62601.html
Best of Luck!
Jorge
Fri Jul 31, 2020 3:16 pm quote
Professor,
I wanted to upvote your reply, but as a good-for-little "Lurker" I was unable ...
So thanks!!! Consider this a public thanks and I will send the order in to both HF and one of our favorite scooter supplier supporters....
/Hw
S 190. Custom VNB 150
Fri Jul 31, 2020 5:42 pm quote
That harbor freight tool is exactly what I used to remove mine. Use the secound smallest wedge. It just barely fits and the smallest one will slip out.
I have extra bearings if you need one. I can drop it in the mail. Let me know.
Sun Aug 02, 2020 12:46 am quote
And use plenty of heat on the casing around the bearing. But you must use a heat gun, not a hair dryer. The trick is to heat quickly. You almost don't need a puller at all. I never use one, just heat. They all just pop out on their own once you know the technique. But it's always nice to have the puller to hand just in case you get one that is stubborn.
S150, Beo 500ie
Sun Aug 02, 2020 7:50 am quote
Thatís a cool photo. Presumably the oil drain is in the side thatís been removed.
How does the oil get up to the top gear/bearing? By splash and adhesion from the lower gears?
Sun Aug 02, 2020 8:10 am quote
If the tools take a while, youtube Vespa bearing removal bread method
Sun Aug 02, 2020 10:34 am quote
Your right, it is all just splashed lube. There is no pressure applied to the oil, it is just like a car differential
Fri Aug 07, 2020 8:30 pm quote
https://damagedboatsandbikes.com/2018/05/07/will-bread-%F0%9F%8D%9Eremove-a-pilot-bearing/
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.1984s ][ Queries: 27 (0.0325s) ][ Debug on ]
