Engine light turns on when riding Piaggio MP3 above 3000 rpm
Tue Aug 25, 2020 1:58 am quote
I have a Piaggio MP3 2007 and I enjoy it very much. But the last time I was riding it, the engine light turns on (orange). I noticed that it happens when the engine is making more than 3000rpm and the light turns of at idle (below 2000 rpm).
What could be the issue here?
50cc Beo, BigBeo
Tue Aug 25, 2020 5:29 am quote
Just a guess: check voltage at battery at idle and over 3000.
Tue Aug 25, 2020 4:51 pm quote
Your voltage regulator has died.
Replace it.
If this has been happening for a week or more, consider replacing the battery as well, as this will have been stressed by >17V being presented to it.
Wed Aug 26, 2020 5:55 am quote
Thanks!
My voltage regulator does this:
At idle, it gives between 13 and 14 volts. When I throttle more, even a bit, it goes up to 18 volts.
I'm not familiar with this. Is such a high voltage wrong?
Is a voltage regulator replaceable myself?
Gilera Fuoco 500ie
Wed Aug 26, 2020 5:57 am quote
regulator got them in stock
Piaggio MP3 500
Wed Aug 26, 2020 6:49 am quote
Yes, you just need to locate it and remove a body panel to get to it, then the new one just plugs into the harness. But do it soon- 18V is way too high and it's stressing all your electrics from the ECU's to the battery, and could end up being very expensive.
Wed Aug 26, 2020 7:38 am quote
gwbonline wrote:
Thanks!
YES!
Yes.
Fri Aug 28, 2020 10:13 am quote
It was the voltage regulator. Replaced it with a second hand alternative and the engine light never turned on again. And the bike rides like a charm! Didn't know this makes such a difference.
MP3 400 "Orion"
Thu Sep 03, 2020 3:12 pm quote
I'm afraid this is what's happening with my machine. The symptoms sound exactly the same. Where do I find the regulator, what panels do I have to remove to get to it, and where's the best place to get a replacement?
Thu Sep 03, 2020 3:24 pm quote
You can lead a horse to water...
Page 57 of the workshop manual:
https://manuals.wotmeworry.org.uk/Piaggio/Piaggio%20MP3/MP3%20400/
https://scooterpartsco.com/ricambi/080-oem/oem-voltage-regulator-for-vespa-250-300-piaggio-aprilia
MP3 400 "Orion"
Thu Sep 03, 2020 3:34 pm quote
Thank you.
Your Rally Here   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.2499s ][ Queries: 27 (0.0494s) ][ Debug on ]
