Can both a 400's front wheels be removed at the same time?
MP3 400 "Merlin"
Tue Sep 08, 2020 7:58 am quote
I apologize if this has been asked before.
Can the 400's front wheels be removed at the same time for tire changes? If so, where's a good jack-up point?
2009 MP3 400, 2004 Honda ST1300
Tue Sep 08, 2020 8:35 am quote
I use a regular automotive floor jack with a piece board on the pad to spread the load a little. Then just lift gently under the fuel tank. Not super stable that way but it gets the job done.
I suppose if you had the right facilities you could hoist it by the handlebars.
MP3 400 "Merlin"
Tue Sep 08, 2020 8:39 am quote
Thank you. We're doing it the one-wheel-at-a-time method but it's a half hour trip one way to transport the wheel to get the new tire mounted and balanced.
Moderatus Rana
MP3 250 (sold) MP3 500 (current)
Wed Sep 09, 2020 6:37 am quote
Another option is to have a spare set of front rims then you can get the new tires mounted and balanced and install them whenever you want to. I do this for the rear to minimize down time.
MP3 400 "Merlin"
Wed Sep 09, 2020 11:25 am quote
That very thought occurred to me during my second trip back to the shop.
Wed Sep 09, 2020 6:36 pm quote
yes you can do a double front removal. need to cut a 4x4 to fit between the axels of each somewhere around 22" , then using a floor jack under the 4x4 carefully lift the complete front end just so the fronts are barely off the ground.
2008 fuoco
Sun Sep 13, 2020 12:35 am quote
See my posting it's on the second page of the forum, titled, "lifting the front end safely.
Team Scooter Trash for Petfinder Foundation   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1874s ][ Queries: 25 (0.0421s) ][ Debug on ]
