Engine swap
P200e gts 250 166 disc
Sun Sep 13, 2020 11:48 pm quote
Hi will a 2005 vespa disc engine fit straight into a 1982 p200e frame not worried about ele start etc thx
1964 GS 160 MK II, 1967 Vespa GT, 1968 SS180, 1964 Vespa GL, 1964 Vespa VBB, 2006 Buddy 125, 2013 BMW C650GT
Mon Sep 14, 2020 4:02 am quote
Re: Engine swap
Just ignore this. I messed up!
Oops
P200,Rally180, 100 sport , SuperCub50
Mon Sep 14, 2020 1:31 pm quote
"...with major fabrication, modifications and throw your wallet at it!"
less than you think.
Mon Sep 14, 2020 2:24 pm quote
If you want to keep the starter motor bolted to the '05 PX case, then you will need to trim some sheet metal near the VIN. If you decide to remove the starter motor, then the '05 engine will slip right into any year P with zero modifications.
1981 P200E / 1979 P200E / 1974 Rally 200
Tue Sep 15, 2020 12:34 am quote
Are these frames different at all?
This is a P series, and an LML PX frame that you can still buy new.
The engine area looks the same, except for a slightly raised area on the LML one.
XqGsl_iMoi-zBexIu7A5AGbBg349c5xVuqOAOmeAUNZ5fJvcUc6PNhg380n9B8ZaAUZt03aqvRv1XCk2ckR0zlHlFY1vCjpshIkf1QQ.jpg
1979 P150X, 1983 P200E, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Tue Sep 15, 2020 2:17 am quote
Both are PX type. Top one has the newer lock / main switch. The raised part at the engine bay is for the electric starter...
Tue Sep 15, 2020 6:27 am quote
What Safis said....both of those pics are PX/LML frames. Neither one is a P frame.
2007 Stella 150
Tue Sep 15, 2020 8:50 am quote
Re: Engine swap
I just bolted a P200 engine into a 2007 Stella, no issues at all. I didn't keep the electric start. There really only two nuts and bolts holding the motor in. The front large one that the motor pivots on and the shock bolt. The only issues you may have, which are not hard to overcome, are the wiring maybe a little different. You may have a 5 wire stator in the 2005 and a 7 wire in the 1982.
Tue Sep 15, 2020 12:47 pm quote
I see. The metal on the frame is cut a bit higher around the engine?
Tue Sep 15, 2020 1:25 pm quote
Notice the difference where the rear shock is. Both are mine. Top is my P and bottom is my T5 (the T5 has basically a PX frame with the extra tail section). So if I wanted an E-Start engine in my P, I would need to cut the frame...
Tue Sep 15, 2020 1:36 pm quote
You can really see it there.
Wow. I had no idea the T5 frame looked like that. Piaggio didn't stamp a new frame, just an additional piece with a seam.
Does it have the regular PX tail section underneath it?
Tue Sep 15, 2020 1:59 pm quote
Yes, it's exactly the same except it has two holes for a tool to reach the tail light bolts...
Tue Sep 15, 2020 3:10 pm quote
The paint looks beautiful!
I had never seen a T5 up close. They were never imported to North America.
Tue Sep 15, 2020 3:21 pm quote
I think there's currently about a total of 5-6 T5's in Washington and Oregon? No idea about the rest of the US or Canada though. Back in 2007 i saw a T5 Millenium that showed up to the Amerivespa that was held in Seattle. It a had Canadian plate. I'm guessing the owner brought it over from the UK?
08 GTS 250, 79 P200E, 62 Allstate
Tue Sep 15, 2020 7:42 pm quote
I got to see one up close a couple of weeks back at the TDC Rallye event in Eugene Oregon. I forget the story on it. Crappy pic, but you get the gist...
Thu Sep 17, 2020 3:41 pm quote
My bad. I thought he meant a CVT 200. Yeah, on my 67 GT I put in an 05 PX200 crate motor I got from Vader. Put the rest of the parts in, took off the starter and put a plate over it, bolted it in, wired it up. Ran it 3,900 miles in 11 days in 2016.
He was kind enough to toss in a Vaderbuilt Malossi 210 top end that scares me!
Fri Sep 18, 2020 2:03 am quote
Was just talking about him today. Do you know if he made adjustments to the port roof angles? I know he talked about doing it, but can't recall if he actually did.
Rallies Europe 2016   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.3425s ][ Queries: 25 (0.0756s) ][ Debug on ]
