BV500 Will not start.
2006 Beverly 500ie
Mon Sep 14, 2020 5:06 am quote
i find myself in a bit of fix,
have been vacationing the last few days on a greek island and scooter is taking me everywhere without issues starting etc.
bv500ie
today went to go start it and its cranking but it wont fire
battery is new
fuel pump is fine its pumping (and replaced 1 month ago entire unit)
the island has no mechanic and i have limited tools at my disposal.
fuses have all been checked
emergency switch checked
kickstand checked.
spark plug cable has been checked and made sure its in place etc
anything else i can check
Mon Sep 14, 2020 1:14 pm quote
Check the injector is actually spraying fuel. Check you actually have spark. One or other of those is awry...
BV250, BV500
Mon Sep 14, 2020 10:42 pm quote
Definitely open up the inspection port in the left side floorboard plastic and make sure the spark plug cap is firmly attached and that the cable is seated in the cap.
2006 Beverly 500ie
Tue Sep 15, 2020 1:13 am quote
after some fumbling about looks like there is no spark going to through the cable to the plug.
BV250, BV500
Tue Sep 15, 2020 10:45 am quote
The cap unscrews from the cable. Hold the cable tightly with one hand and unscrew the cap with the other. Look in the cable end. If you see the wires in there, all the way to the end, good. The look in the end of the cap you just unscrewed and make sure it's clean in there. Then screw them back together snug but not really tight.
Was the cap hard to pull off the plug? Does it snap back on when you push it on? If it does, try to start it again.
2006 Beverly 500ie
Sun Sep 20, 2020 7:07 am quote
just to close the thread
took the bike to the shop, and
the culprit was a blown fuse it was shorted but you couldnt tell it was burnt out. 3 of us had looked at each fuse one by one. anyway.. (fuse in question was the 5amp fuse in the back fuse box)
the fuse was burnt out due a short created by the left turn signal connector touching the metal of the left brake lever.
Buddy 125, Scarabeo 150, Scarabeo 500ie, Triumphs, Vespa Sprint 150
Location: Charleston,SC-Knoxville, TN- Sanibel, Florida
Mon Sep 21, 2020 3:55 pm quote
Thanks for the update.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.1344s ][ Queries: 25 (0.0248s) ][ Debug on ]
