Question about the Oil Pump Pinion Shaft (1980 P200e)
P200E
Mon Sep 14, 2020 1:42 pm quote
I don't see any reason why not but I've been wrong before. Can I insert the Oil Pump Pinion Shaft after the engine is assembled? Mine is quite chewed up and I would like to continue with the engine assembly while I track down a replacement shaft for my 1980 P200E.
2005 PX150 In a Love-Hate Relationship with a 2-Stroke Vespa Since 2007
Tue Sep 15, 2020 1:29 pm quote
Yes, in fact that's how I usually do it to avoid it sliding out at the wrong time while moving the engine around on the bench.
It goes under the carb air box.
Just make sure you put it in with the spiral section up, else it doesn't fit in properly.
Cross Egypt Challenge - A 2400km ride throughout Egypt   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1929s ][ Queries: 28 (0.0363s) ][ Debug on ]
