VX/gts
Joined: 23 Sep 2020 Posts: 1 Location: Canvey Island essex
Wed Sep 23, 2020 2:57 am
Hiya
I have mangled the crank on my 125 runner I've been offered a Piaggio GTS 125 engine although they do looks the same am I correct in saying they will just pop over OK they are both carb engines
Wed Sep 23, 2020 3:32 am
if back rim size is same you should be good. I just had a friend blow up a vespa 50 4t. I first could not find a replacement engine. I thought the fly 50 4t from same year would work. it looked same in pics. bought one only to find the two used different size rim. so case length and brake drum were different. the engine was not a direct swap by any means.
