P125x engine in Douglas 92L2. Poor job?
'58 Douglas Vespa 92L2 with '81 P125X engine
Thu Oct 01, 2020 1:51 pm quote
Hi new to this so bear with me.
Im beginning to think this conversion wasnt done very well as it seems off centre. The rear wheel isnt central to the body and the cylinder head snags on the bodywork.
Theres box section welded underneath to hold the smaller p125x swing arm.
Wondering if i should remove that and use a proper conversion kit? Or is it ok as is?
Thu Oct 01, 2020 2:07 pm quote
use a proper conversion kit. that looks like some cobbled together nonsense.
also, change your kickstart lever out.
if you don't have a cylinder shroud, you need one.
-g
Thu Oct 01, 2020 10:53 pm quote
Hmm suspected as much.
Any recommendations/links on what conversion kits and kick starter?
Ta.
Fri Oct 02, 2020 1:11 am quote
Nothing takes the soul out of a Widebody like installing a Largeframe engine in it.
That being said, zero fuks were given when they installed said LF engine in this.
  DoubleGood Vespa T-Shirts
[ Time: 0.3146s ][ Queries: 25 (0.0475s) ][ Debug on ]
