I replaced the engine and have most parts of the old engine. I bought it with less than 14,000 miles, with a rapping sound. It was lighter than a rod rap. Took the top end apart and I believe the wrist pin had seized at the connecting rod. The piston felt loose on the con rod and the pin was hard to drive out. So I have everything else except the flywheel cover and the drive system. Head, cylinder, cam chain, flywheel and oil pump, etc., as well as the reduction gears. I also have the assembled crankcase with the crankshaft and connecting rod, but I'm not sure of the condition of the small end of the con rod.
Want something? Message me and be specific. I'll get you a photo and a price.
