Malossi multivar 2000
Lx 50 2T 2012
Wed Oct 14, 2020 11:45 am quote
I have a stock vespa lx 50 2T and I want the best first bang for the buck mod. Is the malossi multivar 2000 a good option? Do you suggest any other mod first? If the multivar is a good option what will the result of this will be? (Better acceleration? top speed?...) any answer will be much appreciated
Sponsor
Granturismo 218
Wed Oct 14, 2020 1:03 pm quote
Big bore kit
Expansion Chamber
Racing Variator
In that order are the most bang for the buck. You probably can't find an expansion chamber for the LX 50, and they do tend to piss off everyone around you, especially when you decide to ride home at 2 AM. So big bore kit and variator are going to give you the most. Malossi is as good as it gets when it comes to performance variators.
Sat Oct 17, 2020 1:29 am quote
malossi 70cc top end kit, leo vince SP3pipe (remove the restrictor), red malossi airfilter, slight upjet on the carb. change the rollers in the stock vario
done. 55 all day, can still get up hill, reliable.
*edit to add, moto is right. throw a vario at it as well.
but kit first. then everything else compliments it.
-g
Sat Oct 17, 2020 1:53 am quote
Since there are two authorities on mechanics and modification (greasy125 and Motovista ) i wanted to ask something ...
Does the ribbed on which the variator rotates wear prematurely if stressed beyond the manufacturer's specifications?
Sat Oct 17, 2020 2:15 am quote
i have no idea what you're asking about.
show me a parts diagram with numbers and specifics and maybe i can tell you?
anything performance wears out faster and requires a closer eye towards maintenance.
-g
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.2191s ][ Queries: 25 (0.0285s) ][ Debug on ]
