Vespa ET4, AF (A/F Air Fuel) mixture screw
ET4
Thu Oct 15, 2020 4:41 am quote
I have 2001 Vespa ET4 (150cc).
I have a question concerning AF (A/F Air Fuel) mixture screw.
As I turn this clockwise and screw it more tightly into the carburetor body, does this make the scooter run more rich or more lean?
Please let me know from your concrete experiences instead of random guesses. Some motorcycle AF screw controls fuel flow and some controls air flow.
Thanks a lot,
2010 S50 Modified "Punkin"; 2003 ET4 150 "ISO"
Thu Oct 15, 2020 12:56 pm quote
Greetings:
Walbro WVF carb, right? OUT is Rich. I have that exact carb from my 2003, swapped for Keihin CVK that was introduced in 2006. Both work fine, but improved considerably with deletion of U.S. Canister evap recapture system.
2003 Vespa ET2
Fri Oct 16, 2020 10:22 am quote
this tip has always helped me:
if its on the airbox side of the carb, its for air...out is more air
if its on the intake side (out) its for fuel...out is more fuel
Sat Oct 17, 2020 1:03 am quote
here's a quickie: run the screw out until it is just flush with the carb body orifice where it threads in.
do this while the motor is warm, and double check the function of your choke.
but that seems to be the sweet spot.
you may need to bump the idle speed down a hair, but other than that you should be rock and roll.
-g
Cross Egypt Challenge - A 2400km ride throughout Egypt   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.1397s ][ Queries: 25 (0.0361s) ][ Debug on ]
