Help with lights?
2016 Vespa Primavera Settantesimo 50cc
Thu Oct 15, 2020 6:36 am quote
Hi. Having trouble with lights. Both left side. Unrelated.
See pics.
Front left Is just loose. How do I tighten that?
Rear left is missing a piece of plastic or rubber inside. How do I fix that?
Any help or insight is much appreciated.
Thanks!
Thu Oct 15, 2020 6:37 am quote
Second shot, front turn signal
Thu Oct 15, 2020 6:38 am quote
Should gave specified - both are turn signal
Lights. Probably clear from photos.
Lx 50 4T, GTS 250, S 150 (Missing in KS), Something Chinese, GT 200 (sold)
Fri Oct 16, 2020 11:24 am quote
This is a typical case to take it to a Vespa dealer. They will fix it in a jiffy.
Fri Oct 16, 2020 11:36 am quote
Vespa Dealer is 120 miles away.
Sigh... yes. But vespa dealer is 120 miles away.
Fri Oct 16, 2020 11:46 am quote
Sorry. Try to adjust the front one by twisting it around gently.
Coul you give us a front picture of the indicators?
The rear one looks broken. I would call Scooerpartsco to see if they have a replacement.
Primavera 150
Fri Oct 16, 2020 11:48 am quote
Scooterwest sells a kit to replace all of the turn signal pods with lights integrated into the existing front and rear lights. Really cleans up the look of the bike. I had trouble finding the kit on their website, so you might have to give them a call. There's a Rocket how-to video on YouTube on how to install the kit.
2018 Vespa 300 GTS Touring
Fri Oct 16, 2020 12:13 pm quote
You mean this video https://www.youtube.com/watch?v=Of3IkDcUMTYand the kit you talking about is this one
https://www.scooterwest.com/led-euro-light-kit-front-only-sprint-and-primavera-mi200-pr-frt.html
But not sure if it addresses the issue he is having.
Fri Oct 16, 2020 12:42 pm quote
Thanks!
The rear one is broken, for sure. Iím thinking I can replace that. But the front one is just loose. And I canít figure out how to tighten it. Iíve wound it around, but itíll only go a turn or two and it feels forced.
Feels like I should remove the panel... but that scares me.
2018 GTV300 SG, 2012 LXV 125ie 2V, 2015 Primavera 3V 150ie and V90
Sun Oct 18, 2020 5:52 am quote
Re: Help with lights?
See pics.
Thanks!
You could use JB Plastic bonder if you do not need to re-open the piece to change the bulb.
Or eliminate front and rear pods, that is my suggestion
Sun Oct 18, 2020 5:58 am quote
If you want to keep the pods, for the front one that needs tightening you take the lens off by removing the screw then the silver reflector has two prongs that secure over the mounting arm, the reattach them. You can buy the rear one at scooterwest for $32
Tue Oct 20, 2020 5:09 am quote
Very helpful... thank you
I didnít know removing them was an option. These posts are extremely helpful.
Thanks so much.
Your Rally Here   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.2616s ][ Queries: 27 (0.0567s) ][ Debug on ]
