how to remove tall windscreen on gts 300 2020
Gts 300 notte
Thu Oct 15, 2020 8:03 am quote
hello, ive recently got the tall windscreen:
[img]https://lh3.googleusercontent.com/proxy/d5C4oK6g5Jqi3vw2r_kr6IuDm0RAgCqmrtMacPVu0o-d2lyvskEJ7FkgaWJuGH3fClsTC3FJAdAnVyxEFxQ__68Dbo3Au5R-pbrzGKWagdbA6C5vDStZSCrNlpA[/img]
not my vespa, but the same wind screen i have.
but the thing is the dealer put it on for me, and i was wondering how i take it off? im guessing you just twist the little bars going into the handlebars part, but i also hear that some vespas have reverse threading on one side and i dont want to strip anything taking on or off stuff.. any help would be appreciated. thank you!
Thu Oct 15, 2020 10:41 am quote
Your image post did not work. Assuming you have the OEM Vespa screen, or a similar one such as the Faco or Cuppini - they are held in by an expansion bolt on each bracket. You loosen the exposed bolt with an open end or adjustable wrench. The bracket should then come out of the sleeve in the headset. Sometimes it is necessary to tap the end with a wood block to loosen it.
2013 GTS300ie
Thu Oct 15, 2020 10:51 am quote
Don't undo it completely!
A few turns and a tap on the lower end of the bracket should be enough.
2016 GTS 300
Thu Oct 15, 2020 11:45 am quote
And both sides are normal threads (no "reverse threads").
Thu Oct 15, 2020 1:39 pm quote
No reverse threads.
Cross Egypt Challenge - A 2400km ride throughout Egypt   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.2194s ][ Queries: 25 (0.0314s) ][ Debug on ]
