MP3 500 will not turn over
Piaggio MP3 500
Thu Oct 15, 2020 4:50 pm quote
i left the ignition switch on for 2 hours, and my 2009 Piaggio MP3 500 will not turn over now. There is no current going to the handbrake micro switch. The running lights, horn, signals work, dash lights up. i cannot read enough on the Piaggio Manual Schematic to determine where the micro switch is powered from. Anyone know of a decent electrical schematic, or what might be a likely cause?
Thank You,
John
Thu Oct 15, 2020 5:01 pm quote
Dead battery. Do you have a tender you can use to charge it with?
Some tenders won't charge a battery that's totally dead.
Piaggio MP3 500
Thu Oct 15, 2020 5:05 pm quote
battery is fine, there is no current to the micro switches
Fri Oct 16, 2020 5:41 pm quote
You can lead a horse to drink...
https://manuals.wotmeworry.org.uk/Piaggio/Piaggio%20MP3/MP3%20500/
Piaggio MP3 500
Tue Oct 20, 2020 6:04 am quote
With the wiring diagram, I was able to trace the test this circuit to stop light/starting function. Sillie but true, it is the fuse for this circuit, which I visually inspected a number of times, and it still looks fine, but has a non visible break shown with a continuity test.
Never assume anything, Ha!
Piaggio MP3 500
Tue Oct 20, 2020 10:30 am quote
Good job! Thanks for letting us know! It makes sense that it wouldn't start if the brake light fuse were blown- the brake needs to be pulled before the starter will engage.
Missouri Loves Company Rally   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1387s ][ Queries: 23 (0.0352s) ][ Debug on ]
