Can this bearing be used for gear selector bearing?
61 Gs150 vs5 , 55 Acma125, 62 Gs160 mk1, Lambretta TV200
Thu Oct 15, 2020 11:03 pm quote
I just bought a needle bearing for using it for px gear selector bearing.
But the bearingI bought (IKO BA188Z) is a little bit different type of bearing.
The needle is less half than the bearing I usually have used.
I found that the bearing I bought has a lower load rating. and high RPM.
But the shape is the same as the bearing SIP is now selling.
The attached files are the information on the bearing.
Can I use this bearing for PX gear selector bearing?
Or throw it away?
Thanks!
bearing I bought new
IKO bearing I bought, load rating
C : 8680N
C0 : 13400N
IKO full(?) needle bearing like original,
C : 20700
C0 : 40500
Gear selector bearing on SIP
C : 12800n
c0 : 20200n
'64 Motovespa 150S (177) , '66 Allstate SF, '64 VBB, '66 180SS
Fri Oct 16, 2020 1:57 am quote
The outer axle/output shaft ball bearing takes the load of the rear of the scooter and the force driving it. It is essentially in line with the center of the wheel. The inner one, basically, just locates the end of the shaft and has relatively little force on it. The axle also turns at a relatively low RPM. I think you'd be fine with it.
Fri Oct 16, 2020 2:31 am quote
Looks like it should be ok. If I'm working it out right your highest rotational speed for the rear axle at 130km/h would be about 2800 or a little over half the top speed of the bearing.
1970 180 Rally, 1980 P150X and P200E
Fri Oct 16, 2020 7:24 am quote
The original bearings had a lot of needles, whereas the new ones are like the one you bought. So far I have not had any problems with the new type.
Fri Oct 16, 2020 12:41 pm quote
Thanks. ! I will use it
Fri Oct 16, 2020 12:42 pm quote
Thanks! is the load rating of 130km/h only 2800n? It's much lower than 8000n..! Thanks!
Thanks!! I will use it!
Fri Oct 16, 2020 5:01 pm quote
No, I'm saying that the allowable rotational speed from your chart is 5500rpm, and that at 130kmh the rotational speed of the axle is roughly 2800rpm - as far as I can work out.
Sat Oct 17, 2020 6:10 am quote
Oh, I see. Thanks for your advice!
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.1648s ][ Queries: 27 (0.0436s) ][ Debug on ]
