No spark on P200
1970 180 Rally, 1980 P150X and P200E
Fri Oct 16, 2020 7:06 am quote
My P200 has suddenly died on me. I tried new plugs and a new CDI unit, still nothing. Then I measured the pickup unit: 116, which is good, and then I measured the ignition coil: 520, which is also within range. Still no spark.
What else can I test or check for?
79p200e 66smallstate 85pk50xl 84p125ets 63GL
Fri Oct 16, 2020 7:34 am quote
Should be 2 green wires going to CDI. Pull the green wire going to CDI from the handle bars. If you have spark, you have a short of the kill wire in the frame.
Also check continuity between white wire and frame. This should have a good connection as it is your ground.
Hope this helps.
Land of 10,000 Scoots Rally   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.1933s ][ Queries: 25 (0.0351s) ][ Debug on ]
