Vespa '90 ('65) Wheels - Rims - Etc.
'65 Vespa 90
Fri Oct 16, 2020 11:34 am quote
Hello All !
Question . . looking to put new wheels and rims on my '90. I'm looking around and I found some I like on SIP and Scooter West. What I'm replacing is 3.00 - 10 wheels (stock I assume) I would love to swap a pair of these rims / tubeless tires on the bike (see pictures) but it looks like I need 5 star hubs to make these rims work ?! Can I assume that (like most other things) the '90 does not allow for star hubs ?! and that these rims are a NO GO !
Please let me know if anyone else has put these rims on a '90 without stupid crazy retro fit add ons.
Thanks as always for the knowledge base and help !!
Boo
Fri Oct 16, 2020 12:06 pm quote
many of the early bikes had 9" wheels - are you on 9's?
'65 Vespa 90
Fri Oct 16, 2020 12:19 pm quote
No - think I’m 10’s !? Here’s a pic of my older wheels that I pulled off scooter. See picture.
Boo
Fri Oct 16, 2020 12:23 pm quote
you have 10's but the older style hubs. You can convert your brake hubs front/rear with some work but probably not worth it unless you must have this....
79p200e 66smallstate 85pk50xl 84p125ets 63GL
Fri Oct 16, 2020 12:29 pm quote
Trying to figure out your current rim situation. If you have 3.00-10 tires, then you have 2.10-10 rims. Question is, what hub do you have?
Older small frames had the 4 lug hubs. Newer had the 5 lug hubs.
The picture you posted also shows a 3.50-10 tire. This tire will fit the front no problem. However, a 3.50-10 tire in the rear will often rub on the clutch cover and drag like the brakes are engaged.
Hope this makes sense.
4 lug hub
5 lug hub
Fri Oct 16, 2020 12:30 pm quote
SDJohn beat me to the punch. lol
Fri Oct 16, 2020 12:32 pm quote
yeah poidog is right - some 3.5x10 rub the clutch cover. tire size can get dicey on the rear. I've run a 90/90 back there because I had a pretty fresh pair laying about (actually it's what's on the bike now).
Fri Oct 16, 2020 12:34 pm quote
options
sip does make this aluminum tubeless if that is what you want.
Similar look.
'65 Vespa 90
Fri Oct 16, 2020 1:36 pm quote
I did see those “other” rims from SIP - and they’re my back up if getting my first choice to fit is a nightmare and involves another 250.00 worth of parts. These older rims fit fine & did not rub or make contact with hubs or body.
So it’s possible to get my first choice to work but it means new front and rear brake hub changes !? Its been done .. but its expensive !? I have tuned this ‘90 with upgraded DR 130 and bigger carb .. is a brake hub / upgrade really necessary .. with the increase in speed !? (look’n for an excuse to upgrade based on safety .. but it seems like a thin defense) Let me know .. THX
'65 Vespa 90
Fri Oct 16, 2020 1:42 pm quote
Here’s whats on the scooter now.
See Pictures.
'65 Vespa 90
Fri Oct 16, 2020 1:44 pm quote
Rear / engine where hub.
'65 Vespa 90
Fri Oct 16, 2020 5:08 pm quote
Thanks !!! Appreciate it !!
74 50s x3 78 P200 84 Cosa PK50XL2 58 AllState 68 Sprint 80 50special '66(?) Super125
Fri Oct 16, 2020 7:58 pm quote
Upgrading to five bolt wheels is not too hard and gives you the advantage of bigger brakes. Made a noticeable difference to me. I had a PK fork w/ 5 bolt wheel, but swapped the hub and brakes on the motor for a 5 bolt. It was easy. For the front, you'd have to swap the axle, but that's usually fairly easy too.
before and after
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1539s ][ Queries: 25 (0.0304s) ][ Debug on ]
