Gts dead as a dodo
Gts125s
Sat Oct 17, 2020 8:04 am quote
I have a problem that I hope you can help with.
My 68 plate gts 125 will not start. The battery is fine, the lights are fine, it scrolls through the start up procedure but nothing at the button. All fuses are fine including the main ones. I have stripped and cleaned the side stand switch and still nothing. Totally puzzeled!
Sat Oct 17, 2020 8:11 am quote
Brake lever switches: does the brake light come on when you apply the brakes?
Starter relay ok?
Sat Oct 17, 2020 10:13 am quote
Agree with JKJ, and also add, you sure the starter button doesn't have a broken circuit? It's old, perhaps something has corrosion blocking good connection.
Sat Oct 17, 2020 10:14 am quote
I don't understand ... Is it a GTS from the year 1968?
Welcome in MV.
Sat Oct 17, 2020 10:42 am quote
Welcome in MV.
This might be what the OP is probably referring to.
https://www.motorcyclespecs.co.za/model/Vespa/Vespa%20125%20GT%20Sprint.htm
Sat Oct 17, 2020 10:46 am quote
OP,
Try the not-so-modern forum.
http://modernvespa.com/forum/forum19
Lx 50 4T, GTS 250, S 150 (Missing in KS), Something Chinese, GT 200 (sold)
Sat Oct 17, 2020 10:51 am quote
TroutBum wrote:
OP,
^^^ this
150 Sprint Veloce,Vespa GTS 300
Sat Oct 17, 2020 2:35 pm quote
I think what the OP means its a 2018 late GTS!
The UK number plate system is like this! https://www.autobulbsdirect.co.uk/blog/car-registration-years-chart/
Graham
Sat Oct 17, 2020 2:42 pm quote
^^^ This sounds right. OP says "it scrolls through the start up procedure but nothing at the button." That sounds like electric start. The older GT/Sprint is kick start.
Sun Oct 18, 2020 12:59 am quote
Some vintage Vespas had batteries and a generator light on the headlight, it is a topic with few and cryptic information; for this i had the doubt.
Sun Oct 18, 2020 8:03 am quote
It's NOT A VINTAGE VESPA! Sheesh.
Sun Oct 18, 2020 11:22 pm quote
Sheesh: "used to express disbelief or exasperation."
Sorry... Now I understand.
Mon Oct 19, 2020 10:56 am quote
Graham
Thanks Graham. Learned something new. Thanks for the link.
Missouri Loves Company Rally   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.3290s ][ Queries: 23 (0.0561s) ][ Debug on ]
