I picked up this Vespa ET2 pretty cheap. The former owner didn't want to pay his mechanic the $275 diagnosis fee to see what was wrong, He was advised that it would probably need a rebuild.
Well the mechanic was right, there was no compression, I found strange metal pieces down under the Cylinder, I assume a ring failed, or it was sabotaged by someone. I will post photos of the metal I found.
But after I split the case to check for more metal scraps, replace bearings and seals, then top-end will be rebuilt with a DR70cc, Malossi Wild Lion Pipe, Malossi air filter, 17.5mm carb, Polini High-Speed variator kit, Polini belt.
Before Photo's / Then after photo's w/some mods done.
