Installed new battery. All hell's broken loose.
MP3 400 "Orion"
Sat Oct 31, 2020 8:14 am quote
EDIT: RESOLVED. Blown 20 amp fuse in main fuse box.
Previous battery, which was only about a year old and kept on a tender, went flat. We installed a brand new battery, tested it with the volt meter, looks good. Turned on ignition and:
- horn beeps continuously
- all lights come on and won't shut off
- tilt lock will not disengage, either via the switch or by revving the throttle with rider in the saddle
- the bike DOES start but does not rev
Looked through the owner and workshop manuals and didn't see any solutions.
So, once again, right when I think we've gotten the bike road worthy again, something else goes wrong.
Ideas gratefully appreciated.
Sat Oct 31, 2020 9:03 am quote
Did you top off this new battery with your tender before installation? A voltage reading can be a bit misleading. Sounds like the battery isn't at full charge.
2010 S50 Modified "Punkin"; 2003 ET4 Malossi 187 "ISO"
Sat Oct 31, 2020 10:27 am quote
Greetings:
Double-check Polarity?
Sat Oct 31, 2020 11:12 am quote
This!
I'm amazed how many people think that a new lead-acid battery will come with full charge and properly equalised cells. Then they complain when it fails after a year - or even when first used!
MP3 400 "Orion"
Sat Oct 31, 2020 11:59 am quote
My husband insists there's no issue with the battery, but I will attach it to the tender overnight. Definitely can't hurt.
2015 MP3 500 ie Business
Sat Oct 31, 2020 12:21 pm quote
Make sure you set that charger to no more than 1Amp charge rate. Using a standard car charger will boil out and/or damage the cells in a matter of minutes.
MP3 400 "Orion"
Sun Nov 01, 2020 12:48 pm quote
Picture of dashboard lights. My husband took this picture. When I sat on it and turn the key on, the same thing happened but more dashboard lights were on. This shows three, I had at least five. He also took video, I'll try to post that.
MP3 400 "Orion"
Sun Nov 01, 2020 12:52 pm quote
Link to video
https://youtu.be/kzvINlU48W0
Sun Nov 01, 2020 1:34 pm quote
Measure voltage at battery with the engine running.
You should see a number between 13.5V-14.5Volt.
With the flickering light, I suspect you either have a bad voltage regulator or a bad battery.
FYI, it appears your vehicle is behind on needed service as indicated on the LCD by the wrench and drivebelt icons
MP3 400 "Orion"
Sun Nov 01, 2020 1:38 pm quote
Thanks, we'll check. We topped off the battery overnight. The tilt lock is stuck "on" so the engine will not rev.
Sun Nov 01, 2020 3:12 pm quote
Even with the 'double-click'?
I suppose the old battery might have failed leaving the tilt-lock mechanism in a weird configuration - but a fresh (properly prepped!) battery should sort that out.
MP3 400 "Orion"
Sun Nov 01, 2020 3:17 pm quote
Even with the double click. Nothing on the bike is responding.
Sun Nov 01, 2020 3:57 pm quote
Have all the fuses been checked? Not by eyeball but with a meter?
MP3 400 "Orion"
Sun Nov 01, 2020 4:17 pm quote
That's the next task, probably tomorrow if it's not too horribly cold out in the garage. It snowed today.
Gilera Fuoco 500ie
Mon Nov 02, 2020 5:30 am quote
or a fuse or lock ecu looks like wrong way arround connected battery
Mon Nov 02, 2020 5:39 am quote
Greetings:
I could not explain the multitude of symptoms ("horn blows incessantly" is a big clue) without the accidental creation of a Positive Earth chassis, even if momentary. What I DON'E know is if this would cause permanent damage to anything electronic after correct polarity is restored. A poorly-charged battery seems to me an insufficient explanation for the scenario first described.
MP3 400 "Orion"
Mon Nov 02, 2020 7:23 am quote
Wheelman-111 wrote:
Greetings:
The battery appears to be connected correctly - neg to neg, pos to pos. What we don't know is if, when connecting the battery, if we accidently touched something that sent a brief jolt of charge the wrong way. Would that fry something critical?
Mon Nov 02, 2020 8:08 am quote
Carolan wrote:
Wheelman-111 wrote:
Greetings:
Almost certainly it'd fry something - but I've seen several scoots that have had the battery installed the wrong way round, and each time the only thing amiss was the main fuse blown.
All the electronics *should* be protected by diodes or internal regulators.
MP3 400 "Orion"
Mon Nov 02, 2020 12:13 pm quote
Update: 20 amp fuse was blown in the main fuse box. It's either slot 3 or 4 - my husband took it out so I don't know which way it's oriented.
He's checking the auxiliary box now.
Mon Nov 02, 2020 1:46 pm quote
It'd be slot 2 or 3 (no.4 should be 15A) - and I bet it was no.3, which feeds the tilt-lock ECU.
Land of 10,000 Scoots Rally   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1629s ][ Queries: 27 (0.0351s) ][ Debug on ]
